Why mount tabs horizontal
Old 11-28-2006 | 06:20 PM
yesrej's Avatar
Default Re: Why mount tabs horizontal
Originally Posted by Tantrum
I think you should install them upside down....that way you can make sure they are way out of the water
your always thinking chris.
yesrej is offline
Old 11-28-2006 | 07:59 PM
Dono's Avatar
you could just mount one verticle in the center like the sail boats do it.
Dono is offline
Old 11-29-2006 | 01:15 AM
Originally Posted by open72
step or straight bottom?..
The Fountain is a single step 29 Fever F1 and the Venom was a twin step 32 ZXR F1 Both have notched transoms.
F1-00 Racing is offline
Old 11-29-2006 | 06:37 AM
Jassman's Avatar
When you run the tabs straight across, it gives the idea of possibly adding some length to the bottom with out scrubbing as much speed off when tabs need to be used in various conditions. Is this what the Arneson rocker plates do? Thanks Jeff
Jassman is offline
Old 11-29-2006 | 09:09 AM
Laken's Avatar
Tantrum, which way should we install them on the NEW SBRT underwater secret weapon
Laken is offline
Old 06-23-2007 | 06:54 AM
Imo basically the same thing but I think Tabs horizontal work better.
Discussed this with some offshore 2 liter racers recently and came to this conclusion.
the thought behind this was that the tabs and the running surface of the boat makes a triangle which is the most effective way of stabilizing.
Feel free to correct/inform me.
MikeyFIN is offline
Old 06-23-2007 | 08:47 AM
FeverMike's Avatar
Originally Posted by CanDo
Installing the tabs horizontal is a very old idea. Far from cutting edge. CanDo
Correct...I saw boats back in the '90s doing this and I'm sure they were doing this before that time too. I saw Bob Bull's F1 Velocity back in 1997-98 with tabs mounted like this...also Miklos and Gary from the F1 Oatey boat played around with tabs a lot from inner to outer mountings as well.
FeverMike is offline
Michael1
11
10-23-2017 09:48 PM
Rage
26
04-13-2012 05:40 PM
mr_velocity
06-11-2004 08:07 PM
envision
04-09-2002 12:11 AM
