496HO w/CMI vs 500efi
Old 12-06-2006 | 06:33 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default Re: 496HO w/CMI vs 500efi
Originally Posted by wiggler4490
They will be very close, both right at 470-480hp, similar torque, and you can expect similar mph . 496 is just a more reliable, closed cooled updated motor, looks cool with the cmi's and a billet cover, or Raylars 103 kit will put you in the 575 hp range .
very nice....just what I was looking for.....thanks
tblrklakemo is offline
Old 12-06-2006 | 06:59 PM
Originally Posted by itilldo
I was under the impression that the Blue motors had beefer internal workings compared to the 496
The top end is better as well.
Anarchy Powerboats is offline
Old 12-06-2006 | 09:33 PM
UNSANE's Avatar
Since I recently discovered my 525 had wrong head gaskets, questionable valve springs, bent bolts, missing pleniums and a blown head gasket pumping antifreeze into the oil..........I'll attest to that. I'm surprised it didn't grenade itself right there!!! We did a full blown inspection and all the bottom end is groovy (except for main seal) and the heads survived as well with only a little corrosion. Went ahead and changed the springs, I'm told that's the only weak link on the motor.
UNSANE is offline
Old 12-07-2006 | 03:16 PM
jrz
To confuse more potential customers, see what happens when you put sport tubes or sweepers on a 500EFI.
jrz is offline
Old 12-07-2006 | 05:35 PM
Too Old's Avatar
Watch for Stellings new 496 compatible offering!
Back to the old screne name.
Too Old is offline
Old 12-07-2006 | 08:18 PM
epeek's Avatar
You changed your name...again!
epeek is offline
Old 12-08-2006 | 12:28 PM
26sonic's Avatar
If I run with twin 496 ho's wot @ 5000rpms with 26p bravo 1 props now what props would I run after cmi install with the additional hp? also how are the stellings going to be priced and what kind of hp ?
26sonic is offline
Old 12-08-2006 | 01:22 PM
jrz
The additional MPH gains from the CMI's will depend on a few other factors. Call 661-295-7000 ask for Bob, he has done quite a few lately and should be able to help.
jrz is offline
Old 12-08-2006 | 01:48 PM
Canada Jeff's Avatar
If the hp500efi is stock, I doubt you would see any gain from going from stock headers to the sport tube, or others. The restriction with the hp's are the heads. Not the intake or exhaust.
From what I have been told by many.
Canada Jeff is offline
Brian C
Wanted
0
06-22-2008 03:00 PM
Outdrive1
Wanted
2
06-12-2008 07:22 PM
mr.scrich
Baja
2
09-29-2007 10:04 AM
John B
07-22-2002 11:30 PM
502KC
26
01-10-2002 12:23 AM
