Stellings extension box refinish >
Old 12-30-2006 | 04:38 PM
RedDog382's Avatar
Default Re: Stellings extension box refinish
Originally Posted by Lucky Strike Jr
The paint on ours started to peel off so we stripped them and painted them with imron. Here is how they came out.
LS, Jr.
Boxes look good. What did you use to strip them with?
RedDog382 is offline
Old 12-30-2006 | 07:29 PM
Originally Posted by RedDog382
Good point. Think I will have them re-shot in Imron. Just need to find someone who can do the job right.
Guess I'm committed ... took one box off today and have everything disconnected to remove the other one tomarrow.
you get em blasted and i will paint them for you... just take care of shipping ...no charge... i use ppg dp and concept single stage...(do for a living)
open87 is offline
Old 12-31-2006 | 11:12 AM
RedDog382's Avatar
Thanks for your very generous offer.
Would media-blasting be better than a chemical stripping? There is a chemical strip shop here in Toledo I have used before and have had good results. Or would chemicals interfere with adhesion?
Would it be better to do a chemical strip and then media-blast?
Old 02-06-2007 | 01:47 PM
RedDog382's Avatar
Making a little progress on this:
Attached Thumbnails Stellings extension box refinish-stellings-004.jpg   Stellings extension box refinish-stellings-001.jpg   Stellings extension box refinish-stellings-005.jpg
Old 02-11-2007 | 07:18 PM
RedDog382's Avatar
Ran into a potential problem with this project. Had the boxes and inspection covers chemically stripped and dusted them lightly in my sandblasting cabinet.
I plan to prime/paint the boxes, but had my powdercoater do just the covers. They bubbled pretty badly. He thinks it is due to residual chemical in the porous aluminum. He even ran them through his oven twice before powdercoating to dry out any residual. The stripping company states this is NOT from residual chemical, but from porous aluminum off-gassing from the heat.
If this is from residual chemical in the aluminum, will I also likely have a problem with primer/paint adherance?
Old 02-11-2007 | 07:20 PM
dukenrock's Avatar
Any luck at Pro Strip?
dukenrock is offline
Old 02-11-2007 | 07:23 PM
RedDog382's Avatar
Kevin,
Busy weekend, haven't had a chance to contact them yet. On my "to do" list for tomarrow. Thanks for the lead.
Chris
Old 02-11-2007 | 07:42 PM
dukenrock's Avatar
I'll contact the powder coater I know tomorrow and see what he says too.
Old 05-16-2007 | 03:52 PM
RedDog382's Avatar
Finally have this project completed:
Attached Thumbnails Stellings extension box refinish-strainers-015.jpg   Stellings extension box refinish-strainers-017.jpg
Old 05-16-2007 | 03:55 PM
RedDog382's Avatar
Very special thanks to (FAT BOY) Mitch in Cleveland. Thanks also to Open 72 for the generous offer, and Dukenrock for the support.
Attached Thumbnails Stellings extension box refinish-strainers-016.jpg   Stellings extension box refinish-strainers-018.jpg
