single v bottom with #6
Old 01-01-2007 | 06:07 PM
  #31
TeamSaris's Avatar
Driver-441
Racer
Default Re: single v bottom with #6
I would
TeamSaris is offline
Old 01-01-2007 | 06:12 PM
  #32
I'm getting ready to build a new boat and what kind of pricing does the complete Konrad setup w/box cost?
Tapa11 is offline
Old 01-01-2007 | 06:38 PM
  #33
Originally Posted by Tapa11
Would you feel alright with a catamaran boat 36' with 900 hp each side and Konrad's on it doing 150 mph?
p.s. I really have a problem with Mercury"s pricing on a no. 6.
JCPERF what do you think of this setup? Then is the price difference worth going away from 6's?
Tapa11 is offline
Old 01-01-2007 | 06:41 PM
  #34
konrads will be about 18k each, wow what cat are you buying 150mph with 900's, don't know asny 36's that will hit that speed with that power.
Buddy OO is offline
Old 01-01-2007 | 07:04 PM
  #35
I guess that was a figure of speech in some degree. I'm just thinking would a 150 mph cat, 32 to 40 feet long, be comfortable with Konrad's, and would it perform, as good or better than the 6's?
Tapa11 is offline
Old 01-01-2007 | 07:08 PM
  #36
TeamSaris's Avatar
Driver-441
Racer
As good at least. If you need any more help we are a dealer so give us a ring.
Old 01-01-2007 | 07:14 PM
  #37
Rod Tshiggfrie.....25 Talon cat.....1300HP.....6A outdrive
http://www.racecrafters.biz/
under "boats for sale"
Not a V-bottom, but I've seen this boat and it was balanced well for it's size.
He used to bring this boat to the Shoot-out but the conditions kept it from reaching top speeds.
He's run this boat in a 1/4 mi drag race and it reached 127 mph. Hang on........
9 Lives is offline
Old 01-01-2007 | 07:28 PM
  #38
JCPERF's Avatar
Konrads are a good choice.The #6 is the best and isnt that much more money.I paid 8K for a mint gimbal and wet sump drive that was run in fresh water only used.There are alot of wet sump 6s floating around
JCPERF is offline
Old 01-01-2007 | 08:10 PM
  #39
cougarman's Avatar
Originally Posted by saxman
There is a guy on this board with a 30' checkmate I believe, has a turbo motor in it and runs 115mph+ with it.
Originally Posted by check300
I have a 30' Checkmate with a #6. We had an extension box made to house the transmission so the engine could stay mounted in a stock Bravo location. It's been an awesome combination.
I'm using a BAM Super Cyborg dry sump behind 1500hp with no trans problems. Have over 100 hrs to date.
I am currently running a twin turbo 572" BBC. The engine is an EFI setup with Haltech engine management. We are even controlling boost with the Haltech. I ran over 20lbs of boost the last 2 years with no failures. A #6 drive was of course necessary to handle the power. The engine is making 1500 hp. and similar torque. The gear ratio is 1:24 with a 16.5" diameter 27 pitch prop. The boat has no trouble getting on plane. The turbos have water cooled heat shields to control radiant heat. The turbo guru who designed and built most of the system is Tom Earhart.
Bill
I have a tranny for my #6 located in the extension box so the engine has not been moved from a stock bravo location.
Marc built just such a box for my boat. We left the engine in a stock Bravo location and put one of Marc's Super Cyborg Transmissions in the box. Puts the prop about 53" behind the trasom. No more broken drives!
Cougarman
cougarman is offline
Old 01-01-2007 | 08:19 PM
  #40
JCPERF's Avatar
Originally Posted by cougarman
Cougarman
pics ?
JCPERF is offline
