Turbine Cat Drive Instillation Help Needed!!!
Here is the web site.
http://www.n2speedturbineboats.com/
The boat I seen is the in lower rite corner
If it aint broke .... I can break it....
Call John Cosker @ Mystic Powerboats, he has designed and rigged quite a few turbine powered cats and v-bottoms. His office # is 386-736-2247.
Good luck,
Dean
Good luck,
Dean
Everything is for sale @ a certain $$
The boat is an aluminum boat made by the same company that fabricated the cougars, I will give them a call see if they can help.
Engine HP is 1600@100%
Rik
I have temporally set up the drive on the back of the boat to show you the stern tube angle and prop height how does this look?
I spoke to turbine marine they said a good stating point would be a prop hub height of 2.5" above the inside of the sponsons with a sterntube angle down of around 3-6 degrees.
Turbines are a lot softer on drives than big diesels or supercharged petrol's. If you check the chart they advise you call for turbine applications.
I have run Arneson drives on all my boats over the years many of which engine torque has far exceeded Arneson recommendation, to date I have never had one fail they are a bulletproof drive system simple but super strong.
Jason
Jason
Don't mean to hijack, but was Jet Set running as often as usual this past summer? In past years, I saw him just about every weekend on the bay. This summer, I never saw the boat once. Now that I think about it, I haven't seen the boat in person with the new paint.
