TBI vs. EFI ?
Old 01-23-2007 | 06:10 PM
Default TBI vs. EFI ?
Being a mechanical novice........can someone educate me on Throttle Body Injection........I am still considering a boat with 575sci's and have never dealt with this type of fuel injection system.......................
Vinny (CM454) you out there?? I know you know this one........
Here's Johnny is offline
Old 01-23-2007 | 06:58 PM
Default Re: TBI vs. EFI ?
Throttle body injection injects fuel at the throttle body,
atop the throttle plates, whereas port injection injects fuel
generally near the intake port of the cylinder head at each
cylinder.
I have 575SCi's and have no complaints.
JaayTeee is offline
Old 01-23-2007 | 08:27 PM
How about at start up.....is it as reliable as EFI ? I have a Volvo 496HO right now........starts everytime.....hot or cold........are the 575's (TBI's) easy to start too......
Old 01-24-2007 | 08:11 AM
Ttt
Old 01-24-2007 | 08:19 AM
T2x's Avatar
T2x
Allergic to Nonsense
EFI is much more user friendly. TBI is an earlier technology and is subject to adjustments when conditions (altitude, temperature, fuel octane) change. EFI has sensors and computerized minitoring that removes all of the concern around those variables. IN addition I'd rather inject at or near the individual cylinder than into a common throttle body before the manifold.
T2x
T2x is offline
Old 01-24-2007 | 08:24 AM
Airpacker's Avatar
TBI is EFI, just injects the fuel in a different place. The 575 uses "wet" supercharging where as the fuel and air mix before the blower thusly lowering the charge temperature of the pressurized air due to the cooling effec of atomizing the fuel. Port fuel injection does not mix the fuel with the air until just before and during the opening of the intake valve and does so in the intake port or just before it.
Airpacker is offline
Old 01-24-2007 | 08:43 AM
Stormrider's Avatar
JC Performance Engines
Johhny, just get dreamers 35playboy.
Stormrider is offline
Old 01-24-2007 | 08:53 AM
Whipple's setup is TBI
cobra marty is offline
Mine start any time.
JaayTeee is offline
Old 01-24-2007 | 03:02 PM
Thanks guys........that helps me out a bit.......
JaayTeee..........you sound happy with the 575's.....do you do a lot of long distance runs (day trips) or more poker run type runs??
