SSM#3 question
Old 01-29-2007 | 12:11 PM
Biggus's Avatar
Default Re: SSM#3 question
Originally Posted by Sean
The only difference between the 3 and 3A is the propshaft. They use the same upper.
The II uses a TRS upper and a crescent lower. It can be bolted up to a TRS but the II has a longer leg and thusly will drop your propshaft deeper in the water...
Right On!
Biggus is offline
Old 01-29-2007 | 12:22 PM
HotPursuit's Avatar
Will #3 Drive bolt to a TRS Gimble? Has anyone done it? Some people say yes. Some say no. What does the survey say?
No way!!!
HotPursuit is offline
Old 01-29-2007 | 12:55 PM
thisistank's Avatar
I thought the innards were a bit more beefed up on the 3A as well.
thisistank is offline
Old 01-29-2007 | 01:26 PM
Mindi
Here you go, gimbals included...
http://www.offshoreonlyclassifieds.com/page-11451.html
Doller Offshore is offline
Old 01-29-2007 | 01:29 PM
Originally Posted by Doller Offshore
Wow, If I hd that kind of money though, I woudn't be trying to piecs together a bunch of parts.
Look like good parts though. Good luck.
jeff1000man is offline
Old 01-29-2007 | 02:10 PM
Sean's Avatar
Tank, you may be right...possible bigger vertical shafts...not 100% sure...
Sean is offline
Old 01-29-2007 | 03:47 PM
Nykamp's Avatar
Tank I think you are right, I thought the 3A's ran the same gear sets and size shafts that the #5's run, but they are just longer.
Nykamp is offline
Old 01-29-2007 | 06:51 PM
thisistank's Avatar
I do know that the shafts are the same size as #6's but are slightly different behind the spline (tapered on the 3a). #6 props will fit the 3A's. and I do think the verticals are the same size as 6's as well.
Old 01-29-2007 | 07:35 PM
HotPursuit's Avatar
Thats correct and no taper on the #3a. The taper was the week spot on the 3s& 4s once they statered running them on the surface!I know this from having many props on the bottom of the lake.
Copied #6 outer and # 4 inner never broke another shaft.
Old 01-29-2007 | 07:38 PM
HotPursuit's Avatar
Depending on last rebuild thats a smoking deal!!!What kind of power was run and salt or fresh?
jeffaker
10-30-2006 05:46 PM
bshzba
12-19-2005 04:20 PM
ratman
2
12-14-2005 10:37 AM
ratman
4
06-23-2005 04:24 PM
thedonz
08-22-2004 09:15 AM
