-   -   Dock Line Organization (https://www.offshoreonly.com/forums/general-boating-discussion/150402-dock-line-organization.html)
tblrklakemo 01-30-2007 09:47 PM
How do you organized boaters keep your dock lines stored and knot free...and where? I didnt do so good a job last summer and purchased new lines anyway.....any ideas? Velcro straps, small bungie cords?
jtmiller02 01-30-2007 10:53 PM
Re: Dock Line Organization
i daisy chain all my lines...but then again on a parasail boat its a bit different, for any long rope though its a life saver
Wild 01-31-2007 08:17 AM
2 Attachment(s)
go to west marine and get some "wrap it up" velcro strips
this is how i keep mine when i need them in a pinch, otherwise i store them under the seat, but the wrap it up strips work great
Gilman 01-31-2007 08:29 AM
I use velcro straps on the oh chit handles on the backs of the seats and it works great.
DoTheMath 01-31-2007 08:50 AM
I can tell you the best way to organize and manage your fenders! :D
dirtlawyer 01-31-2007 08:54 AM
Same here - been doing that for years - my buddies used to laugh at me but now they use them too...
Sydwayz 01-31-2007 09:21 AM
1 Attachment(s)
The Velcro on the grab handles works well, but not my choice.
The ATs have large gunwale compartments down the length of the sides of the cockpit. I can store 3 fenders in each side, and I also place three dock lines on either side, on the floor of the compartment openings. Starboard side is visible in this picture.
When pulling away from the dock, I usually just toss everything into the cockpit. My first mate does a great job of wrapping them around her arm like an extension cord, with a few center wraps with the end of the line. I don't do anything with the fender lines. I just insert them into the compartments with the end that the lines are attached to toward the bow, and the lines just fall into place on the floor of the compartment.
When you are a few hundred feet out from where you are about to tie up, it helps to pull out the fenders and lines you will need, and place them on the backseat, sunpad, deck, etc. where you will need them. This lends to not having to grab for them in a hurry, and getting them all tied into a massive knot.
Chris Sunkin 01-31-2007 10:05 AM
I learned two ways to store ropes. One from an electrician and one from a rock climber.
Electrician-
Lay out the rope to ensure it's not knotted. Grab the two ends. Start coiling between thumb and elbow. When you have about enough that 6" to a foot are left on the ground, start wrapping the remaining rope around the loops you made on your forearm. (remove from forearm first or be prepared for questions) With the last foot, loop it thru the top and pull those 2 ends down on it. You now have a rope that won't unfurl and has a hanging loop on it.
Rock Climber-
Lay rope out as before. Grab ends & double. If it's a long and not too thick rope, you can double it again. Grab the loop end about 8 or 10 inches down. Reach thru the loop and grab the ropes below your hand gripping the rope (making the main loop) and pull thru slightly. Reach thru the second loop you made and pull thru again, keep repeating until you're out of rope. At the end, pull the tails thru and tug until tight, knotting it off. To undo, all you have to do is take that last knot out and pull the tails- the whole thing falls apart instantly.
The best part of these two techniques is that neither twists the rope. The first one turns half the rope one way and the other in the opposite direction. The second doesn't twist at all. The second doesn't work well with large or stiff ropes though.
I'm sure Chapman is rolling over in his grave right now but these work the best for me.
One other thing- wash your ropes and make sure they're dry. Dirt wears them out from the inside and mold/mildew does them no favors either.
tblrklakemo 01-31-2007 10:13 AM
Very nice....I just got tired of asking people to stand up all the time so I could get under the bench seat and get rope or fenders. Usually took time to take the knots out of them too. Fenders now in front and ropes on sides. I might be picky, but I like things to be perfectly organized and in easy reach....especially when we go to tie up with others. And of course I have to redo others work b/c it doesnt satisfy me.
hammer01 01-31-2007 10:19 AM
1 Attachment(s)
For those that are doing the hanging from the seats method, be sure to wash the "new" lines before hanging them on white seats because they tend to bleed into the leather if you are not careful. I always loop them and wrap in the center with the last few feet of the line and the stowage is all up to my first mates, my 10 and 15 year old. I had someone try to rent them (my boys) from me at a dock in loto because they are so good at docking and tying the lines and bumpers. My job is just to get the boat there scratch free and they do the rest. Now they even do most of the driving!!!
ACTIVESHACK 01-31-2007 10:58 AM
My wife tells guest on the boat to tie it any way they like because im going to come behind them and retie it.
t500hps 01-31-2007 11:57 AM
I wrap my lines line Chris's "electrician" method then hang them in the side storage compartment. Yes hang them!. I bought a cheap powder coated coat rack that is meant to be screwed to the back of a closet door. It has 8 hooks and the top 4 will hold (2) 25 ft 1/2 dock lines each. I secured the rack in the upper portion of one of the side compartments and it has stayed there hanging 8 dock lines for 5 years in 3 boats.....yes, I like that thing so much I take it out and keep it when the boats sell!
