Apache Predator P-2 Raceboat >
Old 02-01-2007 | 04:01 PM
Registered User
Default Re: Apache Predator P-2 Raceboat
Originally Posted by Comanche3Six
It has been rehulled, so therefore a new hull number
So is this the one that was dropped and shattered the bottom?
Chris Sunkin is offline
Old 02-01-2007 | 04:25 PM
Comanche3Six's Avatar
No, this is the one that had so many new custom ideas going into it that it was better to build a brand new hull and start with a clean sheet of paper.
Comanche3Six is offline
Old 02-01-2007 | 04:37 PM
Registered User
So what did they keep from the old boat?
Old 02-01-2007 | 04:43 PM
The bimini top
Old 02-01-2007 | 04:44 PM
Time for a pic
Old 02-01-2007 | 05:47 PM
Nauti Kitty's Avatar
McManus quotes the boat at 15,700 with a full cabin. My guess is the builder knows. Probably not as much as you, though.
Not a single 47 apache ever weighed 15,700 lbs. Kemeosabe was very light at 17,500. NK
Nauti Kitty is offline
Old 02-01-2007 | 06:25 PM
Registered User
I agree that none of the old ones did. The 15,700 comes from the builder on what a new one would weigh.
Old 02-01-2007 | 07:46 PM
Bad Ass TA WS6's Avatar
Neat boat but the owner was sort of clueless.
Just some of what he was saying...
Boat weighs 25,000 lbs
$17,000 swim platform
Ventilated crankshafts
I kind of got the feeling he was making it up as he went.
I was half expecting hime to say "...these go to eleven"
Unsure of what the boat weighs. But with all the running hardware, custom one off items, it's probably very close on the trailer. He pulls it, so I'm sure he would know. Wasn't uncommon for the old school 47s to be anywhere from 19-22k pounds on the trailer...
Ever run a custom CNC program on anything? That started as a solid chunk of aluminum, and was machined down. It all had to be designed, and then hand programmed into the CNC machine(s). Then you've also got that huge bad ass one-off Apache logo.
Have any knowledge of how an internal combustion engine works? A PCV (Positive Crankcase Ventilation) system is needed to expell hydrocarbons, watervapor/condensation, and blow-by. IE, unburnt gases that "blow-by" the rings and into the crankcase.
The heat treated BS he spoke about, pertains to powdercoating itself. Powdercoating involves baking items in an oven, for a set amount of time, at certain temperature(s). Finalyzing the powdercoat with a finish normally as bright, and stronger than regular paint.
Bad Ass TA WS6 is offline
fotopress
Apache
7
07-22-2006 01:42 PM
blakea502
04-10-2006 02:13 PM
thor of thunder
10-29-2005 09:36 AM
818181
Pantera
26
04-29-2004 08:02 PM
Fast Shafts
Magnum Marine
1
05-28-2003 01:26 PM
