question on 110 volt outlet >
Old 02-04-2007 | 05:10 PM
jeff32's Avatar
Default question on 110 volt outlet
When my batery switch is ON, when are my 110 volt outlet supposed to supply electricity?
Anytime?
When I turn on my main breaker switch ON ?
Only if I'm hooked with shore power?
Yes I checked, my breaker for 110 volt outlet is ON.
I never used them, and I tried this afternoon and just could not get them to work. Any idea, suggestion?
Or maybe they are in trouble? I don't know.
Thanks!
jeff32 is offline
Old 02-04-2007 | 06:29 PM
Tinkerer's Avatar
Default Re: question on 110 volt outlet
Your 110 V outlets only work when your plugged into shore power or when your genorator or inverter are on if you have either of them.
Tinkerer is offline
Old 02-04-2007 | 06:50 PM
jeff32's Avatar
where would usually be the inverter? Engine compartment close to the batteries or more likely somewhere behind my main breaker panel in the cabin?
jeff32 is offline
Old 02-04-2007 | 08:35 PM
Audiofn's Avatar
Charter Member #232
They are probably FROZEN from the COLD
Put your best foot forward!
Audiofn is offline
Old 02-04-2007 | 08:51 PM
jeff32's Avatar
in heated storage and everything else is working!
jeff32 is offline
Old 02-04-2007 | 08:54 PM
Audiofn's Avatar
Charter Member #232
I was joking
Audiofn is offline
Old 02-05-2007 | 08:11 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
are you plugged in to shorepower? If not have they ever worked not being plugged in to shorepower?
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 02-05-2007 | 08:27 AM
Wally's Avatar
Were doomed!
If you look on your main breaker panel you may or may not have a "DC Main" breaker....when you hit that it runs the acc. of that part of the panel off DC power....if you have a breaker for the inverter in that portion of the panel then you should get 110v when you switch it on....if not then you should only get 110v when hooked up to shore power only...
-Wally
Wally is offline
Old 02-05-2007 | 08:29 AM
Clay Washington's Avatar
Plug into shorepower and see if the 110 works.
You might have a battery charger that works on shorepower. Plug into shorepower and listen for a hum in the engine compartment.
You probably don't have an inverter. With an inverter, your 110 outlet would work without shorepower.
Just my two-cents...
Clay Washington is offline
Strip Poker 388
03-23-2008 04:50 PM
Anarchy Powerboats
4
04-13-2007 11:27 AM
tj309
2
01-10-2006 10:08 PM
Manos
09-01-2005 02:32 AM
