600sci experience?
Old 06-23-2011 | 02:41 PM
  #121
Strip Poker 388's Avatar
Rob
Originally Posted by Dean Ferry
Strip,
That's ok, the more adult beverages for us. And, yes my blowers have the sight glasses. And the oil is supposed to be 5-50wt syn, but what brand?
Thanks,
Dean
A few years back Dustin recommended cas.I usually have to tilt it forward and to the side to get all the oil out.I change mine once a year,I dont run hard and its still clear when I drain it,
Strip Poker 388 is offline
Old 06-23-2011 | 04:08 PM
  #122
Strip,
Thanks,
Dean
This is what I have used (Castrol) I would check with the merc mechanics. I was told not to overfill it. Change once per year.
relaxalot is offline
Old 06-24-2011 | 07:27 AM
  #123
Dean Ferry's Avatar
Veteran: Air Force
Thanks Rob, I see what I think is the drain plug, at the bottom of the of the unit, right behind the blower snout, dead center in the middle. I was thinking all I had to do was just lower the trailer jack all the down and off the block. Do you remove your whipples from the engine when you change your whipple oil?
Thanks,
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 06-24-2011 | 12:59 PM
  #124
Rob
Thanks,
Dean
mine has a allen head plug on the facing it lh side front bottom,Tilting the boat will work good.The last 2 years Ive pulled the motors just to repolish all the aluminium stuff its gets water spots and condesation etc will tarnish the polished stuff.Gives me something to do in the winter
ya can barley see it top center of pick
Attached Thumbnails 600sci experience?-neworleans-race-8-2-08-011-large-.jpg
Old 06-24-2011 | 01:13 PM
  #125
Dean Ferry's Avatar
Veteran: Air Force
Strip,
Thanks for the detailed info. I'm going to have to devise a little drain/funnel/catcher thing to catch the oil as it drains out. I'm also assuming that I fill 8 ozs or till I see it about 1/2 way up in the sight glass?
Thanks,
Dean
Old 06-24-2011 | 01:45 PM
  #126
Rob
Strip,
Thanks,
Dean
I run mine half way,on the trailer and in the water
Old 06-24-2011 | 02:05 PM
  #127
Dean Ferry's Avatar
Veteran: Air Force
Thanks Rob.
Dean
Old 06-27-2011 | 07:11 AM
  #128
Dean Ferry's Avatar
Veteran: Air Force
What is the engine oil qty for this engine? Is it just like an HP500, since they both use a GM 502 block?
Thanks,
Dean
Old 06-27-2011 | 10:06 AM
  #129
Default Water Pick Up
Originally Posted by relaxalot
I bought the boat used with 32 hours on it. It was still under warranty. I did not find Mercury to be very helpful. the tell me the problem is that there were mufflers added to the boat. I tried running without them and had the same problems. There were a few 600's out there with the same problems. My mechanic and Dustin found the problem and solved it. They drilled out some holes on the nosecone, opened up some of the vertical holes and plugged the top three. I alos rerouted the water lines as per Dustin using a separate pickup. The outdrive only feeds the motor. Part of his kit includes some larger fittings to allow more water to flow. The problem was intermittent so it was difficult to track. The boat now runs great.
Relax,
What does your pick up look like and where is it installed? If it's produced by a specific manufacturer, I'd really like to get the specific details. Thanks
Fearless010 is offline
Old 06-27-2011 | 11:08 AM
  #130
Dean Ferry's Avatar
Veteran: Air Force
What else I found this weekend is I BELIEVE I already have this Whipple product installed on my motors? I'm going to try to take some pics tonight.
