525 cam
Old 02-10-2007 | 09:28 PM
BY U BOY's Avatar
Default 525 cam
can i use a 525 cam in a 91 454 that currently has a zz502 cam in it? 1.7 roller rockers 110cc aluminum heads with srp
10:1 pistons 10.7:1 compression, holley 750,zz502 intake..What kind of gains would i see?
BY U BOY is offline
Old 02-12-2007 | 10:20 AM
BY U BOY's Avatar
Anyone?
BY U BOY is offline
Old 02-12-2007 | 10:38 AM
Joe's Avatar
Joe
Offshore Cowboy
You "can", but...............
Just giving you a hard time. I really don't know. Call Innovation.
Joe is offline
Old 02-12-2007 | 04:04 PM
BY U BOY's Avatar
Thanks Joe ill give them a call.
when are we going to see that beast in Texas?
BY U BOY is offline
Old 02-12-2007 | 04:41 PM
Joe's Avatar
Joe
Offshore Cowboy
It'll be heading back this way after the Sarasota run next month (for a while) to do a couple of local "heat of the summer" Texas runs ---- then back to "Poker Run Central" aka Florida for Destin, Sarasota again, KW, and maybe Stuart, SOTW and LOTO.
But, you will most likely see my old boat runnin' around all summer. Careful.... the new owner's driving/docking skills aren't as good as the previous owner's! LOL.....
Joe
Joe is offline
Old 02-12-2007 | 04:52 PM
BY U BOY's Avatar
looking forward to seeing it. so if you see some crazy short phucker flagging you down don't be scared to stop do you plan on running the tickfaw200?
BY U BOY is offline
Old 02-12-2007 | 07:06 PM
525SC or 525EFI cam??????
The 525SC cam is similar in size to zz502 cam.
The 525EFI cam is a Crane roller 741 on a 114 lobe sep.
I would think either would work. You would need retrofit roller lifters, sorter push rods, different timing chain set, and probably different valve springs for the 525EFI cam. I would guessimate a 25-35hp gain with the 525EFI cam and little or none with the 525SC cam.
Griff is offline
Old 02-12-2007 | 08:47 PM
BY U BOY's Avatar
Thanks Griff
i have already done the retro fit to roller lifter/rockers and am running gm performance aluminum heads that are duel spring i am not sure of the tension.I believe these are the heads that edelbock made for gm. so basically i would be better off having a cistom grind done?
BY U BOY is offline
RBT
5
07-14-2011 02:01 PM
Freekazz
4
10-17-2008 09:43 AM
TeamSaris
Donzi
5
08-10-2007 12:55 PM
Leathl_WS6
55
12-10-2003 08:07 PM
John B
31
09-09-2003 01:20 PM
