Best 496 headers?
Old 04-28-2007 | 10:32 AM
  #141
Default octane
It's surprising to me that all the "experts" here (I'm not talking to you professionals) don't know, that high octane fuel is less volatile than lower octane fuels. HIGH octane fuel has a more controlled conflagration rate (it burns slower) than lower octane fuels. Low octane fuel is more volatile and and less controllable than high octane fuel. The reason you get detonation problems from low octane fuel, is from an uncontrolled burn AKA pre ignition!! (the fuel starts to burn under compression or a spark /hot spot in the cylinder ) HIGH octane fuel "burns slower and is less volatile", so you can more precisely determine the "EXPLOSION" point of the fuel in the combustion chamber.
Little girl is offline
Old 04-28-2007 | 07:23 PM
  #142
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
You are quite estute & knowledgable for a "little girl"..
You would also be correct Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-01-2007 | 10:07 PM
  #143
Enough of the Chit chat.. Time for some noise... :yes: :eek!: :bonk: ...
Here is a clip of the Dana exhaust we installed on a clients boat.
Undertaker's new Dana 496 Exhaust running on the hose(click here)
Jamie / Lakeside Restorations
Old 06-04-2007 | 03:48 AM
  #144
Dana's are finally on the boat. I hope to test them on the water this week sometime and I will post real world results after the testing. I must tell you, I also removed the Silent Thunder from the boat, so there are two variables that are changed at one time. There was some weight savings by getting rid of the Silent Thunder...I would guess about 100lbs with all the water that was trapped in it.
Anger Management is offline
Old 06-04-2007 | 10:32 AM
  #145
Good Luck keep us posted on your results.....
Undertaker
Undertaker is offline
Old 06-04-2007 | 10:52 AM
  #146
tblrklakemo's Avatar
SeaRay Sundancer
sweet....keep us posted. What are your before GPS and speedo #'s?
tblrklakemo is offline
speedygonzalez
46
09-29-2008 08:27 AM
Okay4now
10
08-20-2008 07:15 PM
K-WELLS
05-13-2008 05:48 PM
REH
16
10-06-2006 04:07 PM
betitbig
17
02-26-2006 12:44 AM
