Engine flush
Old 03-19-2007 | 06:40 PM
Default Engine flush
I am looking for a fresh water flush system to install on my new Checkmate. I have been looking on the internet and can't seem to find one. I must be using the wrong name. I am sure you guys know what I mean. One that hooks up to a garden hose and not the one that goes onto an Alpha. I have the Bravo drive.
GOFASTJUNKIE is offline
Old 03-19-2007 | 06:48 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
So simple. Don't need to look online for anything.
Tee into the supply right before the seawater pump, run off that tee up to a hose connector. Done!
US1 Fountain is offline
Old 03-19-2007 | 06:52 PM
StillHaulin@63's Avatar
I'm using the PERKO model without any problems!
StillHaulin@63 is offline
Old 03-19-2007 | 06:55 PM
carrboy's Avatar
I have the flush already but have another question...can I run the boat with the hose hooked to the flush?I have a buyer for my 31 and I want to run it for him while he's here...last time I did it I had the muff and I have no idea where it is since the move
carrboy is offline
Old 03-19-2007 | 06:57 PM
Ginger or Mary Ann?
That's the whole ideal behind it. With the hose hooked up and on, water will go out the drive with motor off. Start motor, the pump will suck the water and push it thru the motor.
Old 03-19-2007 | 08:06 PM
you should have a shut off valve if you want to run the motor so you dont loose water through the drive
tony stamis is offline
Old 03-19-2007 | 08:09 PM
sleek1's Avatar
Carrboy,
good luck with the buyer. I know you've been try to sell your 31 for awhile.
sleek1 is offline
Old 03-19-2007 | 08:30 PM
carrboy's Avatar
Thanks guys,I'll let u know how it goes
carrboy is offline
Old 03-19-2007 | 09:13 PM
Ginger or Mary Ann?
You won't. It works. Keep it simple.
Old 03-20-2007 | 07:12 AM
Registered User
I just went thru the exact same search, & did find a couple of kits available. Each had a check ball, & or valve, that troubled me because it seemed as though the outdrive would not be flushed. I did a simple set-up very close to what US1 Fountain did. I went to a local marine hardware, bought the hose fitting adapter from Perko, & then made a trip to Home Depot, bought a "T" 1 1/4 x 5/8, a few feet of hard wall hose, a couple of brass fittings, & hose clamps. I installed the "T" about 1 foot from the sea water pump, installed the adapter in the transom, & then just simply hook the water hose up. Without the engine running, the water dumps thru the outdrive, fire it up, & the water is now pulled thru the pump, & plenty of it. On the muff, I had trouble getting enough water to prime the pump, not a problem now. The whole thing ran me about $40, & took me about an hour to install. Let me know I'd be happy to send ya a couple pics of the install, good luck.
rangerrick63 is offline
