675Keith Eickert
Specifications
Displacement 540 cubic inch
cylinders 8 cyl
Bore & Stroke 4.5 X 4.25
Compression 8.3 to 1
Full Throttle Rpm range 5400
Ignition type MSD/EFI Technologys
alternator 90 amp
spark plug & gap R-5671A-8 NGK Gap.030
oil change intervals 10 hrs
oil type Kendall 20w50
oil filter Fram HP4
Fuel requirements 89 octane
supercharger lube 80w90 non synthethetic
dimensions height31.4 inches/width 28.5"/ length37.5"
J.E pistons
Carrillo 4340 forged steel rods
4340 steel crankshaft
roller hydraulic camshaft
Canfield alum heads
Iron tall deck block 4 bolt mains
Blower shop 8-71 supercharger
Holley Throttle body-Programable EFI
cylinders 8 cyl
alternator 90 amp
oil filter Fram HP4
J.E pistons
Canfield alum heads
Specifications
cylinders 8 cyl
alternator 90 amp
oil filter Fram HP4
J.E pistons
Canfield alum heads
cylinders 8 cyl
alternator 90 amp
oil filter Fram HP4
J.E pistons
Canfield alum heads
My engines were built using the exact specs above
[QUOTE=JoeD;3236357]Specifications
cylinders 8 cyl
alternator 90 amp
oil filter Fram HP4
J.E pistons
Canfield alum heads
Holley Throttle body-Programable EFI[/QUOT. Hello du you know what Kind of injectores are in the Throttle Body ? I Need one of these
cylinders 8 cyl
alternator 90 amp
oil filter Fram HP4
J.E pistons
Canfield alum heads
i replaced a set long ago i think they were gm truck throttle body injectors if you call or send one to a specialist they can tell you the part number then look at rock auto i have received many injectors from them good quality and good company
