No cost tips
Old 02-10-2002 | 04:50 PM
Secretformula's Avatar
Post No cost tips
Ok,looking for no cost or low cost tips. Here's mine from old drag racing days. When changing plugs select plugs that position themselves with the grounding electrodes toward the bottom, this will open the spark to the combustion chamber resulting in ?%hp. Always makes me feel better.
Who has other tips?
Secretformula is offline
Old 02-10-2002 | 04:54 PM
Shorgasm's Avatar
From: On the back of a chicks M3..If you're gonna ride my ass at least pull my hair!!
Cool
Degreeing plugs is an old trick but nearly useless......Try and degree some of the multi-tips out there now.....
Shorgasm is offline
Old 02-10-2002 | 04:58 PM
Tinkerer's Avatar
Cool
On the big block engines--valve notch the cylinders. angle grind the cylinder out to about 1/16 inch from the head gasket at the valve pockets and down to about 1/16 above the top ring mark on the cylinder. This can add 25 to 30 HP.
VALVE NOTCH
[ 02-10-2002: Message edited by: Tinkerboater ]
Tinkerer is offline
Old 02-10-2002 | 06:09 PM
Ultrafine
Post
Indexing the spark plugs is needed for high dome pistons. It is said there is a very slight increase in power if the spark is directed towards the intake valve. It is so minor I doubt it is worth the time involved.
Notching the block is a very good idea for unshrouding the intake valve. If building a new motor you might want to use offset dowels in the block as well. This will shift the intake valve a few more thousandths further away from the block unshrouding the intake valve even further. Offset dowels cost a couple of bucks at most speed shops.
Old 02-11-2002 | 04:48 PM
Looney Tune's Avatar
Post
Cheap tip: marry a mechanic
Looney Tune is offline
littledcsrodshop
08-31-2008 11:51 AM
bolgna
4
01-23-2008 06:23 PM
rangerrick63
01-02-2007 10:50 AM
HiPerf2000
2
05-11-2005 08:24 AM
