Diesel Fuel and Baby Oil
Charter Member #40
Change from 500 ppm LSD to 15 ppm ULSD did have some impact on lubricity, from what I have read. Refiners we supposedly making up for it with an additive(s). Prior to 07, most engine mfgrs approved 5-20% blended bio. Cat is still at 30%. Testing is underway but from what I can gather, it looks like most mfgrs are going to re-evaluate their approved bio levels and probably lower. My guess is potential contamination of the substrate in the DPF's. Should look to get a ULSD bio blend meeting ASTM D6751 or DIN 51606.
Charter Member #40
dgduck13, we had same experience with transit bus apps, no failures either. Just passing on what we were being told by the suppliers. Industry was also on the btu content in ULSD and supposedly refiners helped that
The only issue I have seen on the older diesels is when the new low-sulfur fuel is used for the first couple of tanks it will dislodge some of the build-up in the fuel tank & lines and in turn cause your fuel filter life to be shortened. After a fuel filter change all is well with the new fuel in the older motors.
dgduck we have all ready talked about this in trucks form . i have started adding bio desel to my truck at a rate of 1 gal to 15 to 20 gal of desel fuel. i must say im verry impressed with it . truck runs better and is quieter . i have a friend that is running 100% in his ford and it is a lot quieter and runs a lot better. i'm sold on it. i will buy me a bio desel kit and start making my own . .
Charter Member#1545
Sam
