Help ASAP
Old 05-04-2007 | 11:37 PM
99fever27's Avatar
[QUOTE
If if i loosen the drain plug and let alittle oil out to see if it has been contaminated with water do i need to pump more in if there is no water or will the resevoir bottle take care of that?[/QUOTE]
I think if you had water intrusion, that the water would sit on the bottom of the oil? If that is true than the foaming wouldnt be moisture. I think oil will settle on top of water, wich means you could drain some and you would see some noticable water. Just a drunk theory after a long night of bar hopping...
99fever27 is offline
Old 05-05-2007 | 10:32 PM
BY U BOY's Avatar
Originally Posted by 99fever27
[QUOTE
I think if you had water intrusion, that the water would sit on the bottom of the oil? If that is true than the foaming wouldnt be moisture. I think oil will settle on top of water, wich means you could drain some and you would see some noticable water. Just a drunk theory after a long night of bar hopping...[/QUOTE]
i just had to read that twice but i have been on the boat since 830 and pulled out at 830 so nevermind
BY U BOY is offline
throttleup
General Racing Discussion
7
10-29-2007 06:45 AM
DannyD
3
09-07-2005 09:09 PM
Shane
04-04-2003 01:34 PM
HyperBaja
11-20-2002 10:38 AM
