Garden Sprayers to Change Drive Oil
I have one that I converted and replaced the pickup tube inside the tank with a larger diameter pipe for better flow rate. If someone doesn't want to go through the hassle of making one I will sell my setup for $25 plus shipping. It is the modified tank and hose. All you need to do is add the fitting for the drive (take from your old hand pump model).
Rick
Rick
Rick, get a chrome rigid valve stem from an auto parts store or wheel shop. They have a nut that you tighten over the stud squishing two rubber washers together for a tight seal.
Drill the hole, and remove the shavings. Then affix the valve stem to a piece of wire and fish it through the hole from the inside.
I installed the valve stem on my self-winterization 5 gallon antifreeze jug. I pressurize the jug before I start the motor and the air pressure force feeds the SWP with AF so there are no priming issues. It works great! I posted pictures of this setup some time back. Keep the compressor running while you winterize the motor on the final few moments and it keeps the AF flowing the entire time.
No problem with the valve stem. Get a mororcycle valve stem(at any auto parts store), they through bolt and will hold a good seal. I'm using one like this, and I added garden hose rubber gaskets on either side of the canister wall.
The pisser is when you take it out of the cold garage and put it in the warm truck without cracking the fill neck open....The heat pushes the damn fluid right out onto the carpet......Works great though. I wish i had thought of the air valve sooner...
