WE HAVE a WINNER ... Now What ??Trailerring Tilt Switch not working ^$%#
After bringging the Scarab out of the water on Sunday, the trim of the outdrives (both of them) would only move to the "6" range on the indicators (used to go to 9) and the trailer switch would not move them at all. Is there some type of override that might have kicked in or a limit switch not allowing the drives to go up further. Our bayhouse is only 2 miles from the ramp so i was not concerned about dragging the skeg.
Any ideas on what may be causing this? |
Originally Posted by SANLEONKID
(Post 2123235)
Any ideas on what may be causing this? Check the indicator cable. Might be kinked and bending, instead of moving the indicator. |
The drive itself is not moving regardless of the indicator.
Trim limit switch?
Originally Posted by Jakkle5
(Post 2123642)
Trim limit switch?
Is there one ??? |
(Post 2123649)
Is there one ???
were they up all the way when you towed the boat home the first time? |
Originally Posted by BY U BOY
(Post 2123665)
should be one.
were they up all the way when you towed the boat home the first time? yes... they were |
(Post 2123669)
yes... they were
Could be low on hydralic fluid.
pres the drive trim button and the trailer switch at the same time. If that don't do it look at your wiring.
