Help Volvo DPX Drive problem >
Old 05-25-2007 | 07:35 AM
C_Spray's Avatar
Diamond Member #001
DPX-R (Sorry for the lousy picture):
C_Spray is offline
Old 05-25-2007 | 07:37 AM
C_Spray's Avatar
Diamond Member #001
DPX-A. Same internals, just different cases/castings. The A uses a one-piece upper/intermediate, while the R has separate upper and intermediate castings. Lower units are essentially the same.
C_Spray is offline
Old 05-25-2007 | 07:42 AM
C_Spray's Avatar
Diamond Member #001
thanks Chuck, i was curious because they stamp it on the upper. hmmm . . .ya think they'd put it somewhere on the lower. yes i might be interested in the DPX-A stuff, i can always use spares and i may have some gears. whats the differance between the R and the A drives?
If you pull the props, the gear ratio is (usually) stamped on the rear of the bearing carrier. Got a set of 1:47's? That would be forward gear, pinion and rear gear/propshaft. DPX-A's (1.47) have about 280 hours, DPX-R's (1.59) have about 80 each. Email me through the OSO link and we'll see what we can work out. (You too, MBR.)
C_Spray is offline
Old 05-25-2007 | 08:26 AM
glassdave's Avatar
Neno the mind boggler
Originally Posted by METAL BROS RACING
Look at you, drive hog. I need a spare too
I'l shoot ya a PM Chuck, Thanks
08 OPA High Points Champion
glassdave is offline
Old 05-25-2007 | 12:18 PM
Don't listen to him Chuck, he's completely full of it and broke from working on his supercat POS I'm a much more credible owner for your spare drives.
Anarchy Powerboats is offline
Old 05-25-2007 | 01:43 PM
C_Spray's Avatar
Diamond Member #001
I'll just put everything on ebay and let you guys duke it out....
C_Spray is offline
Old 05-26-2007 | 08:20 AM
scarabman's Avatar
I would be interested in the DPX Rs
scarabman is offline
Old 05-26-2007 | 11:27 AM
Get in line there slappy.
Old 05-27-2007 | 03:38 PM
I would really like your E3's C-Spray
martymar5 is offline
Old 05-29-2007 | 09:39 PM
BOOSTEDSCARAB's Avatar
Thanks for all the help guys, and the parts schematic was awesome! The pin that holds the Eccentric Piston in place was sheared off. It was replaced, but the drive still will not shift into gear, although the shifter feels much better and goes to each detent.
I didn't perform the re-instalation of the set-up,...so were gonna take it back apart and re evaluate everything...maybe the cable is streched a bit now,....and needs replaced?
I'm also very, very curious as to what would shear the pin,....something? Anyone else sheared this pin....and?
We'll see..
BOOSTEDSCARAB is offline
