Most Hour's On A 496 Ho Motor
Your kidding right. With all do respect to much smarter people than I , I think some of you are paranoid. I have 434 hours on a 496ho and an XZ drive and have no Intentionson tearing into either one. Change the oil every 50, And take care of it. I'm shootin for 1000. My friend has a denali with an hour gauge. 300 hours was about 9000 miles. Yes I know a boat motor is used under much more severe conditions. Lets say Its 3 times worse, thats still only 27,000 miles. Gonna rebuild your truck motor at that point? I succumbed to all the people who told me I was nuts for 350 hours on an impeller last year and changed it. Nothing wrong with it, I still have it.
Relax and enjoy the water. Thanks, for reading. I await all the replys telling me again that I'm nuts. Bring it on. JC
Michael
Though I would put my two cents in here since we kinda see a lot of 496's.
First a normally aspirated 496 mag , HO stock or with Raylar kits that is run with good oils, regular service intervals and not abused in normal recreational use should see 500 to 1000 hours before it should require any real engine mechanical service. What do I mean about abuse and normal recreational use.
Abuse is mis-proping the boat to lug the engine or put in on the rev-limiter all the time, overheating the motor, not paying attention to beeping on the guardian system, letting oil levels and oil condtion go to low or spent oil, excessvie idling, SUPERCHARGING STOCK 496's, racing stock 496's, etc., etc.
My professional opinion on normal recreational use is spending approximatly 10% of engine hours at idle to 2500 rpms, 10% of engine hours or less at 2500 to 3500 rpms, 75% of engine hours at 3500 to 4000 rpms and about 5% at 4000 to 5000 rpms.
One of the big keys is freshwater closed cooling, it keeps the motor at a pretty constant operating temperature, which eliminates "cold -hot shock", condensation, and corrsion, rust and scaling problems.
We have received a few 496's for overhaul that have seen 1000 hours or more with this type of service and use and they really were in pretty good shape on teardown. Most of the bottom ends looked great and most of the issues or needs were cylinder head work, valve job, guides, etc. We don't service the iron heads, we throw them away and install our aluminum heads which will go far longer than stock heads beacause of the quality of valves, seats, guides, etc.
I've seen a few practically new 496's have issues and go BOOM! right out of the box and thats because they are mass produced by GM Powertrain at Tonawanda and then shipped to Mercruiser, Volvo, Crusader, etc. and we all know these are not blueprinted motors and sometimes new parts slip through inspection as well as friday afternoon slipups on the line and such and that happens on all mass produced motors.
As a percentage though this seems to be under less than 1-2% of all 496's manufactured which is better than any big block GM has ever mass produced.
If you own a 496 take good care and use and she'll take good care of you!
Want more power reliably?
Then talk to Raylar and we'll try and help!
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
Regards,
Ray @ Raylar
Ed Cozzi
Thanks Raylar,
I'll bring it to you when I hit the 1000.
I put about 6 more hours on St. Clair yesterday and never went over 45 mph, about 3000-3500 rpm. Too rough in a little boat. Didn't know I was actually being nice to It. Good to hear from the guy who knows. JC
TeamPSI
23
12-10-2007 05:23 PM
I don't see the need....unless you are using yours to mix concrete!
