Best spark plug wires
Old 06-08-2007 | 05:43 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Phantom1
OK, here's a question. When is it "time" to change spark plug wires?
its so many ohms for foot of restiance , dont remember the #, Id say 2-3 years
Taylor has some pretty expensive/nice one. I use MSD
Strip Poker 388 is offline
Old 06-08-2007 | 07:54 PM
phillips...
open87 is offline
Old 06-09-2007 | 12:12 AM
articfriends's Avatar
MSD 8.5's never lasted me very long,I bought some taylor 10.5's and they seem indestructible,Smitty
articfriends is offline
Old 06-09-2007 | 12:24 AM
JCPERF's Avatar
The Mercury Thunderbolt white spark plug wires are the sh1t
JCPERF is offline
Old 06-09-2007 | 01:35 AM
2112's Avatar
I like Nology Hotwires;
http://www.nology.com/hot.html
2112 is offline
Old 06-09-2007 | 02:19 AM
Accel 300+ 8.8mm´s here only. works great with no radio interference at all.
With these wires I have noticed a difference.
All other 8mm whatevers none except yellow 8mm Accels which are POS.
Heres the info.
300+ RACE WIRE
Applications: Race engine configurations
Features: Silicone spark plug boots, black wire, stainless steel spark
plug terminals,
Benefits: Maximum energy to spark plug, heaviest gauge
conductor in the industry, 8.8mm oversized racing wire,
complete suppression of EMI/RFI (radio noise)
Construction: 5.0 mm, 8.0mm, & 8.8 mm, 600° F double silicone
construction with a fiberglass braid
Core: HD gauge spiral wound copper/nickel alloy conductor,
magnetic suppression & fully reactive ferrite material, all
Kevlar core, 150 Ohms per foot resistance
MikeyFIN is offline
Old 06-09-2007 | 07:32 AM
29KILROY's Avatar
Msd
29KILROY is offline
Old 06-09-2007 | 09:11 AM
I have used MSD, Accel, and Taylor, But was put on to Scott by are circle track engine builder. These things make Taylors look like spagetti. Check them out http://www.scottperformance.com/wiresets.htm
MidnightRider is offline
Old 06-09-2007 | 09:45 AM
KNOT-RIGHT's Avatar
I run the MSD also.
I ohm mine out each season.
Just did them..... 146ohms on the longest and 96 ohms on
the shortys
G
KNOT-RIGHT is offline
Old 06-09-2007 | 12:11 PM
Rob
Here is some that are 25 ohms per foot http://www.vitekperformance.com/tech...erformance.asp
Factory wires are they claim "good" if resistance is under 1400 ohms/ft,general performance wires ie; regular Accels - 700 to 800 ohms/ft,Accel 300+ Moroso Blue Max Jacob's - 250 to 450 ohms/ft,MSD 8.5's 40 to 50 ohms/ft and then Moroso has a new wire that's 35 to 40 ohms/ft
Im trying to find info on the others
http://www.inct.net/~autotips/plugwire.htm
http://www.mr2.com/TEXT/DavidKucharczyk/ignition.html
http://forums.gmhightechperformance....ion/index.html
cheap test
Grab a water bottle sprayer and add a little regular dish soap and water and spray the spark plug wires WHILE THE ENGINE IS RUNNING . If the soapy water mixture finds a hole or soft spot in the spark plug wire the spark will jump out of the wire and ground itself to the water.
The engine will miss and run bad once the spark comes out of the water. If you see the spark come out of the wire grab that wire and if it shocks you replace them
