TRS transmission
Old 06-10-2007 | 03:22 AM
cuda's Avatar
[QUOTE=Edward R. Cozzi;2157135]
Originally Posted by speedo
To me a "MercTrans" is the smaller aluminum-case with the Ford C-6 guts.
It is a single gear Ford C-6. I had one rebuilt, the input shaft clearanced, and an extra cluth plate installed. As I recall, it was about $1350 to have it done. The BW transmission will require the engine to be moved forward.
Here are some parts out of the Merc transmission they took out when mine was rebuilt. Does it look like it needed it?
Btw, Merc didn't discontinue the Trs drive because it was a bad drive, they did it because Bravo's cost less to produce.
Attached Thumbnails TRS transmission-11-30-012-small-.jpg   TRS transmission-11-30-013-small-.jpg
cuda is offline
Old 06-10-2007 | 08:35 AM
Thanks, Cuda. You confirmed everything I've been saying.
The original post asked asked about a 'MercTrans". NEVER ASKED ANYTHING ABOUT THE BW TRANS USED WITH THE LATER TRS.
Edward R. Cozzi is offline
Old 06-10-2007 | 10:19 AM
Originally Posted by el indio
hey ed cozzi..its been 30 years since the first roy halman memorial fun run to michigan city.wow 30 years,like yesterday.....m.m......roy was ahead of his time........
I remember. Doesn't seem that long ago.
How are you doing? Have you fully recovered from that accident?
Old 06-10-2007 | 10:22 AM
cig28's Avatar
i have a merc tran that was rebuilt about 5 years ago , should have a going through. selling my 28 cig and don't need it any more. sent me a private message with phone# if interested
cig28 is offline
h2oboy
38
01-16-2009 07:17 AM
Rookie
Drives and Lower Units
6
04-14-2008 10:30 PM
overdrive75
2
08-08-2007 04:41 PM
jeff32
06-08-2006 08:56 AM
