How many watts to power a boat lift
united rental, home depot if they have a rental section, action rentals these palces will have them to rent out, pick up saturday to keep the weekend for a one day fee is how they work here in OKC
Great - thanks alot.
Per the installation instructions on that HydroHoist it is required to have 115volts/11amps. I found a conversion guide that says that it is the equivalent of (115X11) = 1265 watts minimum needed. So I should be good with a 2000watt generator unless I'm missing something. Can I get a doublecheck on the conversion.
AKA NoMoBoatin
True. Congrats on that!!!
However, I seriously doubt that the man wants to spend $2000 to get his boat off of the lift until Labor Day........so kindly just go back to not having a phucking clue about anything and making stupid posts!!!! You'll be at 10,000 posts before you know it!!!
I do know alittle about lifts and gen. a 4000 watt will lift a 8000 lb. boat if it's on 1 3/4 or 1 hp motored lift. DO NOT TRY A SMALLER GEN. YOUR WASTEN YOUR TIME BELEIVE ME.
Are you talking about the same lift. I wouldn't think it would take that much just to fill it up with air. Are you talking about powering a motor that actually lifts up the boat or a motor that just blows air into pontoons, which provide the lift.
Not sure if you're gonna run it up loaded with a 2500watt generator. I was unable to lift mine loaded with a generator that size. When under load the initial startup current is pretty high.
Oh never mind, he didn't say hydrohoist in his original post.
Geronimo36
You're the expert, you tell me what breaker I have; I said "I think" which implies that I wasn't sure!
AKA NoMoBoatin
Geronimo36
ratman
03-06-2006 10:15 PM
