Can Supercat Motor be made Reliable? >
Old 09-22-2007 | 08:10 PM
Default Can Supercat Motor be made Reliable?
does anyone have suggestions to bring a 750hp supercat motor into a reliable poker run engine, using 93 pump fuel, can a blower easily be added for added hp, I assume the extremely high rpm's contribute to its short life span.
Buddy OO is offline
Old 09-22-2007 | 08:53 PM
Panther's Avatar
Frank's Marine Service
they are high compression, I dont know about a blower... Most of the RPM is due to the high comp., they make power with RPM instead of cubic inches and blowers
Maybe a different cam...but I would guess that it'll make less power.
From what I hear it's a purpose built engine.
Panther is offline
monstaaa's Avatar
from personal knowledge of individual's using this engine they seem to be dependable in it's present form. as for the blower add on, i am sure it is possible but you can speed up the timer on that set up.
monstaaa is offline
Old 09-22-2007 | 09:25 PM
blower will not work as compression will be too high
thedonz is offline
Old 09-22-2007 | 10:37 PM
Agreed - you do not want to supercharge these engines - run them the way that they are you will be surprised at the engine lifespan.
Gregg Reichman
bidpro is offline
Old 09-22-2007 | 10:50 PM
If you want a pump gas motor, build a pump gas motor. The supercat motors are 12:1 and have a rather large camshaft. By the time you lower the compression 2 points and change the cam, change the accessories, remove the dry sump because it is no longer needed, etc.... you could have built a new motor from scratch. They are some pretty reliable motors considering what they are put through and I would keep them that way and start over with a motor designed to run on 93.
Young Performance is offline
Old 11-27-2007 | 06:25 PM
DirtyMoney's Avatar
ttt
DirtyMoney is offline
Old 11-27-2007 | 06:31 PM
monstaaa's Avatar
to sum it up with correct terminology.
monstaaa is offline
Old 11-27-2007 | 08:32 PM
supercats are around real cheap.Make it a 522 with 10 to 1 pistons, little smaller cam and leave the rest alone.you couldn't build a engine with the parts of a supercat for less than 20,000.Spin it 6600 rpms and it will last for ever.Mine have 25 races on original parts less lifters and springs,keepers and valves,rings and bearings.They have a kryptonite crank,carillo rods,je pistons,brodix with titanium valves,dry sump and splayed billet cap bowtie block.you *****s are on crack.Oh I forgot,killer ignition,jesel belt,jesel rockers,dominator carbs,spring oilers.You don't need dry sump or a 10 inch ***** but it is nice to have
ON THE CHIP RACING is offline
Old 11-27-2007 | 09:15 PM
Contact Frank at Scorpion racing engines.
flat rate is offline
