Scoop Mounting Question
Old 09-28-2007 | 08:58 PM
Sick Stinger's Avatar
Brotherhood #1
Default Scoop Mounting Question
Im going to mount a scoop i just had a quick question about it. When i do cut the hole, is the hole just the size of the air cleaner assmebly or do i make it the size of the scoop. I only ask because if its the size of the cleaner it forces all the air in the engine. If its the size of the scoop some of the cold air gets directed to the motor to cool that off. So what size do i cut?????
Sick Stinger is offline
Old 09-28-2007 | 09:07 PM
bouyhunter's Avatar
I'm not the guy to answer this question from a performance aspect, but I would think if you only cut it for the flame arrestor, you're going to accumulate a lot of dirt over time inside the scoop - which will evetually clog the flame arrestor, and be a bitsh to clean. If you cut it wide open and clean, you'll still be introducing air, but it won't be as "forced".
I'm sure the experts will chime in, but those are my initial thoughts.
And remember - If you ask the question, you're required to post pics
bouyhunter is offline
Old 09-28-2007 | 09:27 PM
Cut it the size of the scoop. This will also ventilate the engine compartment.with a ton of fresh cool air.
Darrell.
DMOORE is offline
Old 09-28-2007 | 11:17 PM
You may need to add vents for air out. The scoop will only let in what can get out. Often this can be done with a hatch door type vent on the stern somewhere. In an extreme case it is possible to swell the hatch even blow it off. Have you ever noticed on the back of the tunnel race boats that flap that blows open? Good luck,
Jim
MOBILEMERCMAN is offline
Old 09-28-2007 | 11:26 PM
Whatever size you cut it, you should make a carb mounted pan so only cool outside air is fed to the engine. More than just a little free power vs. warmer under hatch air.
maddad is offline
Old 09-28-2007 | 11:42 PM
Well if you want to make a tray and seal the hatch to separate the compartment air from the outside air that is one way to do it. I think that way is more involved. If you circulate enough air thru the scoop and thru engine compartment it will do the same thing. Different ways to achieve the same thing, ambient air to the engine.
Jim
Old 09-29-2007 | 09:03 PM
Brotherhood #1
Default pics of scoop
pics
Attached Thumbnails Scoop Mounting Question-0929071131.jpg   Scoop Mounting Question-0929071131b.jpg
Old 09-29-2007 | 09:05 PM
Brotherhood #1
Bouy all for you man, Also if anyone ever need something painted let me know this work is the best. Let me know what you think. If you look at the 1st pic its ghosted 572 SCI. And the 572 pic is the evntilation holes for the scoop pretty trick no? let me know what you guys think its true fire with the colors of my boat
Old 09-29-2007 | 09:11 PM
Originally Posted by MOBILEMERCMAN
You may need to add vents for air out..... . Have you ever noticed on the back of the tunnel race boats that flap that blows open? Good luck,
Jim
Good advice. I also have a 12"x12" trap door that is part of the engine cover. It opens when overpressured.
It's upolstered and blends in with the rest of the hatch. It uses a simple stainless piano hinge and opens and closes as needed.
Darrell.
DMOORE is offline
Old 09-29-2007 | 09:32 PM
Brotherhood #1
Do as you can see i just popped the 572 in the back i like it thinlk its differant
