Blown 2006 496 Mag Ho
Lakeside Restorations.com
Commercial Member
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Ah, didn't know you had an aggressive X-diminsion. I like how the Whipple cleans up the top of the motor. Looks like you stayed with the stock exhaust?
Commercial Member
Yes.. Just a few internal exh mods to open it up.. jamie / Lakeside
I was faster with a four blade than my five blader. More loose, but faster! The five blade worked good if you wanted the boat to be easy to run. Now at 86 mph with my four blade, I AM DRIVING IT !!!! Tabs help.
Commercial Member
You are not wrong. In many applications the less blades the faster the boat can be, however because of my high X dimension I cannot keep the 4's locked up well at all. I have way to much slippage over 20%.. Due to our calculations & water testing.. So I am not looking at it from just a pure speed or handling view.. I just need it to grab better to get the boat where it needs to be..
Anyway Im hoping to get this proped better before winter if I can, our season is rapidy closing as well..
Jamie / Lakeside
Jamie / Lakeside
I agree forged are still the best. However the hypertectic pistons are not as bad as what is commonly thought. The biggest problem with them is that they do not tolerate high heat, lean or imprecise conditions well in comparison to the forged units.. .
So far strong cool runnings..
Jamie / Lakeside
Jamie / Lakeside
Thanks for sharing!
BT
Jamie / Lakeside
Jamie / Lakeside
You did see my props for sale in the swap section right??
Commercial Member
I did but they are too small for me.. Thanks for letting me know about them though.. Jamie
AT Cult Member #3
Jamie, Looks good. What about a small drive spacer to get that drive in a bit deeper? Just a thought. May hurt the top number a bit but a 4 blade will be easier on the stock drive.
Commercial Member
Thanks, I am aware of that, however I would like to have the drive where it is if at all possible.. I dont think the 5 at this height will be much more stressfull than the the 4 at a deeper setting based on how I drive.. Jamie
