Winterizing: why the hell not question??? >
Old 11-02-2007 | 11:45 AM
Airpacker's Avatar
its relatively easy with any bravo butt boat. Loosen one hose clamp at the transom plate. Pull off the hose and hold it facing up. Pour antifreeze into the hose and crank the motor pulling the antifreeze thru the pump, oil cooler and exhaust.When pure pink runs out your exhaust, its done. Then, open the block drains,empty the block. Close em up again. Then just pull the t stat housing and pour in the AF until it fills the block. Total time should be about 10 minutes per motor.
Hint, if you plan on doing this often, replace the block drain plugs with brass radiator drain cocks. Shortens the time necessary and no tools needed after that to drain the block.
Airpacker is offline
Old 11-02-2007 | 02:47 PM
I had friend do the heater thing when he was going out of town and it was supposed to get cold. It got cold, heater quit/broke and he had a cracked block.
Griff is offline
Old 11-02-2007 | 07:17 PM
Originally Posted by CAP071
MY cheap friend use to do that. he never had a problem. Where do you live? How cold of an area?
It's not a matter of being cheap here, it's a matter of using the boat every 3 weeks or so during the winter. I live in NC so weather is somewhat unpredicatable during the winter.
wet_rat is offline
Old 11-02-2007 | 07:24 PM
thanks for the responses guys, I think the leaving it in Florida idea is best, the drive for me is 5 hours so it would be worth it.
wet_rat is offline
Old 11-02-2007 | 10:55 PM
CAP071's Avatar
OH NC Yea just drop in a heater n u will be fine just watch the local temps
CAP071 is offline
Chart
3
11-01-2006 04:09 PM
Jerry B
26
09-14-2006 11:17 AM
DORaymond
7
11-13-2005 05:35 PM
OG Outlaw 24
10-08-2003 12:04 PM
283CHECK
4
11-05-2002 09:38 PM
