Kryptonite boats
#91
When I rigged it I was on the phone with Kirk, owner of Kryptonite performance boats many times We took all his advise and got the customer the 100mph plus he wanted, in a rock solid ride.
After runing his boat I realized it was one of the fastest and most stabil boats in its class. I found one by mistake (looking thru repo reports and auctions) for used boats to sell at the marina. The price was right and I got it.
Now I have it, it is far from as stabil as the one we rigged. So here I am working on why and what I will need to do to get it where it needs to be. If I put a standoff box on the one we rigged I could just copy that design but we did not.
The Imco box does that work with the ITS standoff? That would put the drive out there. I will look into it.
Don
#92
I'm by far not an expert on this but, no I don't think the ITS will work with a box. That would be 12" from the box plus 7" from the ITS. Plus all the steering that goes through the ITS system. You would most likely have to get a standard transom assembly to go with the extension box...plus external steering. That would add up $ quick! But you would be able to sell the ITS assembly to offset the cost. Maybe play with some more props first.....
#93
I ran the boat with a 4 blade bravo and it chine walked a little.Did you runn it with the tabs down a little yet? Those tabs are 20 inches I believe, I realize they will scrub some speed. what about putting a spacer in for the imco? the x is too high correct?
#94
Are you measuring the bullet on the drive at the bottom of the V? The drive bullet is the only thing that matters.The 5 blade makes it too squirley ? I only ran it with a 4 blade. I also didnt have more than 20 hrs on the rig when I sold it to buy my 382 formula.
#95
No Brian ,,He Is Too Low,, Don With What Your Telling Me I Think You Are Gunna Have To Do A Reglass On The Transom To Get To Where You Want To Be,That Drive Must Be Real Low,If You Put A -3 On There It Should Be Right Around Where Mine Was,,Put Up Some Close Up Shots If You Can So We Can See ,,
#96
The bravo did work much better, tabs helped some but to get it under controll it scrubed t much speed.
Let me see if I can get some close ups in the morning, The boat is at the Marina and I just got home. I will see what I have here also.
Thanks to everyone for pulling together and working this out with me, I apprecaite everyones time and effort.
#97
Here are some pics, i went to the marina to get some. I did the best I could with the measurmants. I could not hold a strait edge, rulr and camera. This should give you an idea. Thanks for the help.
http://im1.shutterfly.com/media/47b9...D550/ry%3D400/
#98
Some more, prop shaft parallel to the bottom of the boat. Looks like 3.125 below the bottom of the hull.
#99
My friends second Kryptonite is set up with 2.75 inch x-dimension,no box or its. He had the boat built with out pad and with knotch. The boat ran 108 on gps 800hp 32 b-1 @6400rpm. Removing the pad improved the handling of the boat.
#100
I built one with out the ITS standoff and it is 3.25" and runs great, but the same X with a stand off box is putting the drive therotocally and actually much deeper in the water. I am sticking with the ITS on this one, I just need to figure out a plan to raise it a few inches.
Any pictures of that bottom with out the center pad?
