Whipple Charger-
Old 11-29-2007 | 11:31 PM
  #31
Strip Poker 388's Avatar
Rob
Originally Posted by fountain40icbm
That boat would work well also!!
Just think turn the boost up and race gas and be 1000plus.
Strip Poker 388 is offline
Old 11-30-2007 | 06:36 AM
  #32
Canada Jeff's Avatar
Originally Posted by lt
I installed a 3.3 whipple and dart aluminum heads on a HP 500efi and went from 84mph to 112mph in a 25 daytona, it's 3 years old and never had any issues , very pleased.
Which Dart heads did you use? I ask because I have to port match them to the Whipple intake. Not a very good match stock. Did you do this? I am running the Pro one seris.
Canada Jeff is offline
Old 11-30-2007 | 07:30 AM
  #33
lt
Jeff I used the cnc ported 335 heads, I did not match the ports when installed, but I am currently building a 557 quadrotor with the dart cnc 355 heads and I will certainly see how they match up(or don't match up?)FYI we spoke briefly before you installed your whipple, Rob at HTG is building the 557. Larry
lt is offline
Old 11-30-2007 | 07:36 AM
  #34
Oh, O.K. cool, question, did you look into the 5.0 whipple? Instead of the quad rotor? Also, tell Rob to double check your push rods apone assembly....;-)
Old 11-30-2007 | 07:48 AM
  #35
Nauti By Nature's Avatar
Default looking to upgrade b&m to quad or new 5.0
looking to upgrade b&m to quad or new 5.0 , can you tell me
if you need intercoolers for 540 or less ci , with 800 -900 hp?
Just listed them in classified with intercoolers !
Need feedback thanks
Nauti By Nature is offline
Old 11-30-2007 | 08:05 AM
  #36
Rob
On the Whipple kits They are made for/into the lower intake. I wouldnt run it without a innercooler.
I am hearing the 5.0 is a lot more money that the Quad?
Old 11-30-2007 | 08:08 AM
  #37
Whipples are awesome blowers. I have about 100hrs on a pair of 3.3s, no problems so far. They sound really cool when they are making boost
ApacheCarl is offline
Old 11-30-2007 | 08:15 AM
  #38
something like 6200 for snoutless blower I was Quoted ,
for radial w305r / how much for quad carb do you know aprox ?
Old 11-30-2007 | 08:18 AM
  #39
would like to find some some quads setup with carbs maybe
anybody have them?
Old 11-30-2007 | 08:26 AM
  #40
Registered User
Originally Posted by ChiefApache89
Thanks for the explanation Chris. Trust me, we have enough soot on our transom so we're not running lean!
Still learning about blowers and things like that. We're doing some maintenance on our blowers this winter and Rob's been great in explaining everything and what it does along the way. Just helps me understand a little bit better when you goes start talking your talk!
By running lean, I don't mean intentionally jetting lean. I mean having something go wrong and disturb fuel delivery to your cylinders. Something as small as a piece of dirt or a failing pump can restrict fuel supply- it only takes a few seconds to go from smooth running to Chernobyl inside your motor. There's a very fine line between max performance and meltdown with forced induction.
Maintenance, diligence and a willingness to replace some key parts even though they're still working is the only way to successfully live with blowers.
I'm anxious to try this on the set of motors I'm building now. If iot does half of what they claim and what people have said it does, it's worth the $$ just for the meltdown insurance, let alone the performance gains.
http://www.jandssafeguard.com/
Chris Sunkin is offline
