Konrad/Speedmaster IIIA conversion >
Old 12-11-2007 | 01:33 PM
Mindi
Originally Posted by BROWNIE
Dang it, Mindy, that is not a bell housing, it is a gimbal housing.................
Dang it yourself Brownie, give me a little more credit than that!
You could call it a helmet I guess......
from the press release.....
"All that’s required is to pull the existing Speedmaster drive units, pull the hinge pins from the SSM gimbal ring, remove the drive bellhousing and install the specially designed Konrad SSM conversion bellhousing. "
Doller Offshore is offline
Old 12-11-2007 | 01:36 PM
Originally Posted by dwtinc
Whats the cost
alot
open87 is offline
Old 12-11-2007 | 01:50 PM
Mindi
Hold on, the cost is not nearly what you would think it would be....NEW TECHNOLOGY, lot's of prop options open up due to the prop shaft change, and no longer obsolete equipment on your boat...
Miami Boat show will be the debut, please do not quote me until it is official, but somewhere in the 10K a side range...Compare that to rebuilding your broken IIIA's (if you can find the parts...)
Old 12-11-2007 | 02:02 PM
so then about the same as a trs conversion... should work out for boats with a #5 drive too..
open87 is offline
Old 12-11-2007 | 02:06 PM
Dang me, dang me, they oughta take a rope and hang me....................
BROWNIE is offline
Old 12-11-2007 | 02:18 PM
NJSONIC's Avatar
Great job Mindi. Glad to see more reliable conversions going on.
Tom
NJSONIC is offline
Old 12-11-2007 | 02:20 PM
TeamSaris's Avatar
Driver-441
Racer
Proud to be a Konrad Dealer!!
TeamSaris is offline
Old 12-11-2007 | 02:34 PM
Mindi
As we all are! Konrad has a terrific dealer network.
More information can be found on their website, www.konradmarine.com
Lot's more pictures and details coming, check back!
Old 12-11-2007 | 03:21 PM
Panther's Avatar
Frank's Marine Service
Originally Posted by Panther
Is Mercury sill producing the replacement parts for the SSM III/IIIA gimbal housings/rings? If not, do you offer replacement parts for the SSM gimbal housing?
Panther is offline
Old 12-11-2007 | 03:45 PM
OldSchool's Avatar
Not really....you can sell the #3's for more than you would get for trs's.
So,actually, it's less than a trs conversion.
OldSchool is offline
