C M I 's
Some people I know (very low numbers) have had them since the late 90's without any problems and others I know went thru sets like they were going out of style.
I have installed a few sets of the Sport tubes on customers boats in the last few years and even bought 2 sets for my new motors ( not yet installed in boat). Now I am having second thoughts and I am considering going with Stellings and Ebaying the CMI's.
from what i have heard some of the triple eng. setups were not supported properly causing problems on the 525's. My cmi's on my 500efi's are 2000 models, Leon did a repower on it a few years ago and i have not had any problems, i pull both sets over the winter and pressure test with air, so far no leaks,
pulling them off in a week to check before season starts, i hope my luck holds
I wonder if the grade of Stainless Steel CMI is using is not as good of a grade that the others are using,being there corroding/rusting causing leaking???
That would explain why the salt water boats are failing more than fresh water
I think my Dad can answer that. He has been through the 525 headers and the CMI E-top and I think has suggested to CMI on the correct material to use, but I will double check. His shop in an aerospace one so they know what to use that will make it last.
not sure on the grade but I seen some stainless rust, Maybe the higher grade stainless might not hold up to heat or get brittle and crack?
