Carb or EFI....
I think EFI is great for most people. In rangerrick's case, I would go carbed. Sounds like he has the knowledge to fix them if there is a problem.
Witch means the builder has much better control of the combustion efficiency. Not to lean, not to rich, just perfect all the time at any RPM. Easier to offer warranty aswell. Customer's can phuck with it and blow it up, then call for warranty.
If your fimilair with Carb, then go carb. I'm sure you will be happy.
I've had way more problems with carburetors over my lifetime than fuel injection - chokes not working, flooding, accelerator pumps weak, jetting wrong at altitude, leaking bowl gaskets, jets plugged, throttle bodies sticking, secondaries not opening, and on and on - even carb ice! I can't think of even one problem I've had with fuel injection, although I always use good quality gasoline, with a good detergent package, which I think is key.
Michael
Michael
