Best Upgrades 496ho???
I'm looking to dump between $5-10k this spring into my 496HO I was wondering what upgrades would be recommended in this price range and still retain reliability.I'm am also considering moving up to a twin 496HO boat within a year and would like to be able to reinstall this upgrades into the next boat .Any suggestions?
raylar bck-103 kit. gives you 100 hp bolt on for about $6400. buy a prop and have some $ to spare.
2 Attachment(s)
Performance and good looks!!!
CMI Headers! Let us know if we can help. Ateco Engine and Dyno Shop (847)623-2737 |
Whipple. And you don't have to pull the motors apart.
Darrell. |
sorry, but the cmi's wont really help speed on their own....they do sound great but are wayyyyyy to expensive. Do the raylar or whipple it and combine one of those with the CMI's.
live wire, there is a used raylar kit complete in the classifieds as well as used cmi headers all for the 496
When a bubby Whippled his HO in a 28ft Conquest Cat, he went from 60 to 76MPH. Thats a big jump.
Darrell. |
Originally Posted by Marine Toys
(Post 2409295)
Always start with the Exhaust, and get one that you can up grade the HP with.
This usually loses about 100 lbs and gives 10% more horse power out of the gate, there are many to choose from. Dana, Eddie, CMI They are all good, just different price points. 100 lbs..? not from 496 exhaust(already aluminum.) Getting rid of the cast iron heads, yes. The 496 exhaust upgrades just dont justify their high cost. Lots of threads on this. The stock units flow pretty well. |
Live Wire. See my old thread about the same issue.
http://www.offshoreonly.com/forums/s...d.php?t=165776 http://www.offshoreonly.com/forums/s...d.php?t=171004 good luck.. I checked out the possibilities. HP- VS- $.. is the end result.. |
1 Attachment(s)
The CMI exhaust looks great and adds sound, but wont increase perfomance, at lease not on my old boat, I gained nothing from the exhaust change, but it did take awhile to install.
where's raylar??? must still be working.
http://www.raylarengine.com/kits.html http://www.raylarengine.com/hotboat_1.html |
live wire and other 496 owners.
Myself and many others who use our upgrades will tell you that our systems are the best bang for the buck while still keeping the engine reliable and running on 87 pump gas. Call us we'll keep it simple and you'll know the difference. Best Regards, Ray @ Raylar |
Originally Posted by live wire
(Post 2409257)
Hey Live Wire I have your upgrade in my yard :D Just kidding. I would definitely go with the Raylar Kit. Besides, I would love to have your boat with a kit as a demo in the area :evilb: |
(Post 2409257)
Originally Posted by Raylar
(Post 2409431)
If you Whipple it, which will give you the best bang for the buck, be sure to have the computer tuned with the engine on the Dyno. To go even further for better religability, change the pistons, and rods. The pistone and rods are the weak point in a blown 496. Oh, make sure you have a forged steel crank too. Merc stoped using the forged crank a few year back.
This recomendation is from experience. We are rebuilding two 496HO whipple engines. Rod and piston failure, not sure what happened first. |
(Post 2409257)
I have a complete 502 we built and just dynoed 531 HP I will post a pic when I get to the shop. 10000.00 |
Thats a great option!! Pull your stock engine, and run that 502ci engine. Then if when you sell the boat, throw the HO back it her. Or sell it and get so $$ back.
Originally Posted by tblrklakemo
(Post 2409310)
As for the upgrade, my first suggestion would be to save your money for the next boat. Second suggestion would be Raylar. If you Whipple a stock 496, sooner or later you will eat a piston. |
If you can find 93 octane gas, then Whipple it! :D
If you can only find 87, go with Raylar. Good luck! :cool: |
Originally Posted by Griff
(Post 2409575)
My suggestion..........Save your money for the next boat and get 500's or 525's in it.
Originally Posted by Knot 4 Me
(Post 2409680)
Early 496 exhaust manifolds were aluminum but they are now cast iron. Not sure exactly when the switch occurred. Ray would know.
As for the upgrade, my first suggestion would be to save your money for the next boat. Second suggestion would be Raylar. If you Whipple a stock 496, sooner or later you will eat a piston. Not sure thats true. I think all are and have been aluminum.....I have on 01' with alum and my neighbor has an 04 or 05 with alum....the elbows are SS. I would agree 100% on the save the money issue for the next boat. I just caught myslelf wanting to spend cheese on my HO...so i bought a dirtbike instead. :cool-smiley-027: |
(Post 2409257)
Run some boost through them biatches. :D |
Originally Posted by GLH
(Post 2409954)
I will quote the best lime I have ever heard on OSO...
Run some boost through them biatches. :D I have Forged stock replacement pistons in stock for the 496's You will need them. I have them with the stock wrist pin size or I have the pin bushings and .990 pin size pistons. |
(Post 2409951)
Raylar Hear I Come
Thanks everyone for your help but after much debate and a nice converstion with Ray from Raylar.I have decided to go with the 100 HP Raylar kit mostly for the fact that I can run it on pump gas and retain the existing exhaust manifolds to keep it quiet when the kids are aboard and around the marina.Beside the great bolt on power I like the fact that it is still reliable and user friendly and that doesnt compromise the short block components.The boat currently runs a solid 74 and with this upgrade should put me at 80+mph .Which for me in this boat is plenty for now.
What's the ball park cost on the Raylar's?
$6400
Originally Posted by obsessed1
(Post 2409291)
nevermind i found it.
(Post 2410545)
(Post 2410545)
(Post 2410545)
Originally Posted by Hot 4 Teacher
(Post 2411307)
Good choice. Do yourself a favor and get a good 02 sensor. FASS has a nice unit that measures both sides and can mount it in the cockpit.
Or do you mean Pyro's ? |
1 Attachment(s)
(Post 2411319)
wow.....74 out of a 288? on the GPS?
(Post 2411463)
It ran 75.2 with the wind and current and 72.4 against for an average of 73.8mph
I agree with the hyd steering! Changes the boats feel huge!! WAY more control. I have run a 288 without hyd steering, it was like a different boat.
(Post 2411594)
That is not a GPS speedo so I assume those numbers are off of a handheld GPS? If so, wow!!! You by far have the fastest 288/496HO boat out there! Congrats! If you do not already have hydraulic steering, I highly recommend you add it when you install the Raylar kit. You will want the saftely factor running the speeds you will see post-Raylar. In fact, you are already running numbers where you need hydraulic steering.
What does hyd. steering usually cost .Between the raylar kit,a b blade prop and pumping up the stereo is about I want to dump into this boat since I'm looking to move up to a 32' .Is the Hyd. steering just something nice to have or is it manditory.The boat tracks and steers perfectly now even flat out.
(Post 2411594)
Thanks on the congrats, but I have run next to another 08' 288 496HO running well into the 70's and have heard of other 288 running in the 70's as well. |
| All times are GMT -5. The time now is 07:59 AM. |
