H2 pulling a 38???
Registered User
Electric brakes do work in reverse. Surge brakes do not- unless you're trying to back up a hill.
Moving a 747 requires a TUG GT110, It weighs about 90,000 lbs and is powered by a 300 hp turbodiesel.
You're right. Not everyone has significant resources. Owning a boat comes with the burden of owning all the equipment you need to operate it or paying for those services. Just because I can't afford to burn 200 gallons of premium a day doesn't mean someone else should pay for it, regardless of how much I want to go out running every day. If a person's boat is to heavy to tow, they either need a bigger truck or a smaller boat. Can't afford it is never an excuse. Although, it's a common justification criminals use for their actions. This fellow asked and got straight, level-headed, factual answers.
He's talking 300 feet, maybe we should get a level and stick out to measure the ramp incline, although Mr.Sunken and I really don't have to worry we both have dooley's and neither of our boats run anyway. RIGHT CHRIS!!!!!!!!!!
Registered User
While true we didn't ask about relative ramp incline, I've yet to see many really long, really shallow one's. One's you could pull a 12,000+ rig up when wet.
Registered User
Yes. Simple system. An electromagnet contacts the face of the inside of the drum- looks like one side of a brake disc. The friction rotates the magnet actuating the brake cam. The will work like really wet drum brakes though but at 1mph you don't need much. You'd have to manually activate with the controller to get the force you'd need.
I can't recall ever seeing straight electric brakes on a boat trailer--aside from something huge like a tandem dually or bigger.
Surge brakes were the standard. Electric/hydraulic is quickly becoming the standard (see more new ones with E/H than with Surge), and Straight Electric is definately not the norm.
If you remember my old posts about the brakes on my trailers you really need to see someone, as I have never said anything about the brakes on my trailer. As I know, nothing I have would even be worthy of Sydway's intellect. Kind of like his explination of the velocity of pipes,as in stepped hulls. Oh and by the way I am a licensed Master plumber and know alittle abiut pipes but never understood until I saw your explination. Haaaaaaaa just busting your chops!!!!!! Love both Mr. Sunken and Sydway's!
Registered User
I'm doing a changeover on a Myco right now. Going with the greasable spindles, 6-axle discs and the E/H setup. A little over 2 grand for incredible peace-of-mind.
And BTW, I didn't make up the whole pipes/steps analogy; rather a boat designer/architect.
