Cat vs V
Old 01-31-2008 | 02:58 PM
Default Cat vs V
Does it cost more to build a Cat vs V hulls.An example being a 27 foor Nordic Thor vs 28 foot Nordic Heat.Or a Eliminator cat vs their Eagle V hull.If they have same engine drive combos why do the cats seem to cost so much more?
getchasum111 is offline
Old 01-31-2008 | 03:02 PM
The actual production cost has to take into account the materials, do cats take more glass etc and labor hours, such is it eaiser to lay-up a V.
excalibur32 is offline
Old 01-31-2008 | 08:17 PM
Ptufaro's Avatar
I think it is supply & demand & with the same power a cat is faster, and speed cost money.
Ptufaro is offline
Old 01-31-2008 | 09:43 PM
LostinBoston's Avatar
yes
LostinBoston is offline
Old 02-01-2008 | 02:04 AM
It seems like you have more to lay up, which would increase the cost.
Michael
Michael1 is offline
Old 02-01-2008 | 08:58 AM
BLee's Avatar
Charter Mod
If you compare apples to apples they aren't more expensive at all. Go check the price on a brand new 46 Outerlimits or Rough Rider vs a 46 Skater or 44 MTI with equal power.
BLee is offline
Old 02-02-2008 | 02:06 AM
I doubt you can accurately use the retail price as an indicator of production cost. The manufacturers all have different profit margins.
Michael
Michael1 is offline
Old 02-03-2008 | 08:04 AM
tks
Old 02-03-2008 | 10:21 PM
A cat costs significantly more to build then a V bottom. First off the surface area of the hull bottom of a 27' Cat is nearly twice that of a 27' V. Secondly a cat has a ton of 90 degree or tighter turns (i.e. sponson deadrise to vertical) with very tight radiuses. All of this translates into a much more complicated layup process along with a more complicated coring package. When you take the center pod out of the equation the layup becomes somewhat less complicated but still more surface area and still more direction changes then a V.
If you could actually charge for the difference in cost, The cat would be much more costly then a V of similar size (more so then they already are). Hope this helps.
stripp is offline
Cash Bar
02-03-2009 02:52 PM
Ratickle
07-25-2008 02:40 AM
Tim G.
12-15-2003 07:25 PM
1HYPER1
03-19-2003 09:46 PM
cgarrett
11-24-2002 02:35 PM
