496 Chirps WTF
Old 03-02-2008 | 05:00 PM
Default 496 Chirps WTF
Receving fast chirps from the alarm sounder when the ignition key is turned. The first time the ignition is turned on the chrips are momentary and then you can hear the fule pump prime and chrips stop. If you turn the key off and back on again the chirps persist and you can hear two relays on the clacking on top of the engine.
[YOUTUBE]http://www.youtube.com/watch?v=vIsAFtK2r0I[/YOUTUBE]
Last edited by Donzi Corleone; 03-02-2008 at 07:03 PM. Reason: utube clip wasn't working
Donzi Corleone is offline
Old 03-02-2008 | 10:06 PM
If they stop when you start it, its normal. Its more than likely the low oil pressure alarm. The key on activates all the electrical, including the sensors, and since its not running, there is no oil pressure and the alarm sounds.
Griff is offline
Old 03-03-2008 | 06:37 AM
Pwrbt33's Avatar
It almost sounds like a loose connection. I have had a boat in the past that did that when the cable was loose on the starter. Let us know what you find out. You should get a 2 to 3 second steady alarm and you should hear the relay click on the engine and then it should stop, upon key up. The steady alarm doesnt seem right at all.
Pwrbt33 is offline
Old 03-03-2008 | 08:05 PM
The problem is intermetint, after a few turns you might get the 1 beep and it will start right up. It will fire after several attemps are made. Almost like it resets itself.
Old 03-03-2008 | 08:12 PM
Lauderdaleboats's Avatar
Pull the canon plug and push it back on. Loose connection. Very common.
Lauderdaleboats is offline
Old 03-03-2008 | 08:37 PM
Is it the round plug thats an inch and half around the back side of the motor?
Old 03-03-2008 | 08:45 PM
That's it.
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
bn
4
01-15-2005 07:40 AM
NVRENOUGH
3
02-18-2002 12:25 PM
