Looking for propane injection for my 7.3L >
Old 02-18-2002 | 04:40 PM
Comanche36SS
Default Looking for propane injection for my 7.3L
Does any body have a system in use on their diesel now and who should I check with?
Old 02-18-2002 | 04:51 PM
FA18Driver
If you haven't already looked there go to www.ford-diesel.com and register on the BB and ask. They will have all of the scoop you need........
Old 02-18-2002 | 05:27 PM
Comanche36SS
neverfastenuf, do you have their number or web site handy? That is who I was actually looking for. Thanks!!!
Old 02-18-2002 | 05:33 PM
A friend of mine did it on his 2002 F-350 Dually and was not impressed.
Pure Energy is offline
Old 02-18-2002 | 05:36 PM
Charter Member#1545
I have been running the ATS systems for over 2 years in the PSDs and believe it is the best available. Power increase is amazing and EGTs are the same when propane in injected(25-30%). We are a distributor for them. The # for ATS is 800-688-8726
Neverfastenuf is offline
Old 02-18-2002 | 05:42 PM
Cool
neverfastenuf. What are you towing that you need the extra power ? I am towing aroung 10,000 lbs with an F350 crew cab dually 4x4 with 4:10 gears and no problem. How many miles do you have on the engine with the conversion ? I have read about this in a couple of RV magazines but always questioned the long term reliability of an engine equipped with the modification. If you do the math, the pressure generated from the addition of propane exceeds the load carrying capacity of the main bearings. I am not suggesting it doesn't work or that it is not durable. I am just curious.
h2owarrior is offline
Old 02-18-2002 | 06:41 PM
Charter Member#1545
I run an Excursion and a Super Duty. The rig I use most is the Super Duty. I run the ATS 3 stage chip and propane. I pull a 300 Eliminator Eagle, a 32 camp trailer, a 20' enclosed motorcycle trailer and a 30' Featherlight enclosed snowmobile trailer. I run 37" Goodyears and that is what "dampens" the ole strokers a little. The snowmobile trailer, loaded to the gills(6 sleds and gear) is what gets a little tough. The 7-8% grades in this country can keep a good truck grunting, and I hate the right lane (LANE OF SHAME). I only have 4500 miles on the Excursion but around 50000 on the Super Duty, most of them with trailers hooked to it. It has been trouble free except for a convertor(aftermarket extreme duty convertor) that gave up the ghost around 5000 miles ago. The propane actually helps run lower EGTs in some instances. When on a hard pull the propane really helps and gets you "over" the top.
jcburris
2
08-27-2006 09:20 AM
East Coast B
06-13-2003 10:50 AM
crmax
4
05-20-2003 09:22 PM
