Honda Marine
Old 04-06-2008 | 07:54 AM
drew0982's Avatar
Cool Honda Marine
So I've got this 17' hull that I've been putting together for fishing, that I plan to sell. It's got a 90 Honda Outboard, but I don't have a control/throttle box for it.... I have a Yamaha, but it doesn't seem to want to work (the yamaha is pushing the throttle, when it needs to be pulled). Can't find a honda ctrl box or a reverse kit for the yamaha on the island.... Any ideas?
drew0982 is offline
Old 04-06-2008 | 01:59 PM
LapseofReason's Avatar
Well if you have a console the cables run into use a short cable to run to a spot in the console you can mount some linkage, find out how far it is from forward to reverse on the motor, cut a piece of steel an inch longer, drill a hole at each end and in the middle, mount it on a bearing or bushing and fix the short cable on one end and the one to the motor on the other, you need to mount the cables to something so they move the linkage not just flop around in there but that should do it. It would be a lot easier if I was there or could see it but thats an easy way to change direction. Can you adjust the throw on the shifter ?
LapseofReason is offline
Old 04-06-2008 | 03:09 PM
drew0982's Avatar
Sounds complicated! I've tried adjusting it.... I can get it to move fwd, but only about 1/4 inch. If I had the reverse kit for the Yama Ctrl Box, it would work fine, but I can't find one local
drew0982 is offline
Old 04-06-2008 | 03:52 PM
Who else is reading this and sees what I am saying can draw it and post it .You can't get anymore simple than a metal bar with 3 holes in it a cable at each end and pivots in the middle. I would think if they made a kit it would be something like what I said because it's so simple.
Old 04-06-2008 | 03:56 PM
jhiguy377's Avatar
you're right lapseofreason; a simple bellcrank.
jhiguy377 is offline
Old 04-06-2008 | 08:05 PM
A yamaha control box i dont thik will work with a honda motor. I usually switch them out .A honda control box is around $300.00 I think at retail.
BobbyB is offline
Old 04-07-2008 | 09:59 AM
drew0982's Avatar
As soon as the rain lets up, I'll give this a shot. I think I understand what you're suggesting now.
Cheers!
Andrew
drew0982 is offline
Buddy OO
08-17-2005 08:51 PM
Iggy
07-25-2003 06:03 PM
mikev
06-26-2003 03:14 PM
