Top Speed In General
Old 05-06-2008 | 09:33 AM
Default Top Speed In General
In general what should the top speed of a 21ft V-hull boat with a stock 365hp 454cu Bravo I outdrive and trim tabs be? I understand it depends on weight in the boat, of the boat, water conditions, hull design, etc. Just looking for a range.
Thanks.
CenturyUltra is offline
Old 05-06-2008 | 10:05 AM
ENFORCER24's Avatar
From 50 to 80mph , but very dependent on what kinda boat , could even be faster then that , but your not giving us much to work with here
ENFORCER24 is offline
Old 05-06-2008 | 10:13 AM
Advertised top speed of a Pachanga 22(20'6") with 330 HP was 66 in 1987. Had an alpha drive so that helped a little.
pachanga is offline
Old 05-06-2008 | 10:52 AM
Dave M's Avatar
Veteran: Navy
A '21 Superboat will run around 80 MPH with 365HP.
Dave M is offline
Old 05-06-2008 | 11:58 AM
65-75 is most likely
Griff is offline
Old 05-06-2008 | 01:39 PM
jbraun2828's Avatar
Ran 68 in that exact setup with a 22ft Checkmate
jbraun2828 is offline
Old 05-06-2008 | 02:10 PM
Its a Century Ultra, considered 23' but that is with the swim platform, I think its more like 21'.
Old 05-06-2008 | 02:24 PM
Gladhe8er's Avatar
1996 22' Scarab(20' w/out platform) ran about 62-64 with 330 HP/Bravo. Probably would have seen 67-68 with 365 HP.
Gladhe8er is offline
Old 05-06-2008 | 02:41 PM
87 wellcraft 23' nova-tall heavy boat- 330horse/bravo 55mph
This shows how weight effects mph
Tow-N-One is offline
Old 05-06-2008 | 05:45 PM
26 Infinity (25' with out the plat form) 454 Mag 350 HP Bravo 1 Mirage prop. 1" above std "X" dim 69.3 I gues a 21' -22' would go mid 70's. Mine is a relatively light boat for a 26'
PARADOX is offline
