Chevy 350 HO Crate Engine Fuel? >
Old 05-07-2008 | 08:48 PM
Default Chevy 350 HO Crate Engine Fuel?
In 2000 I put a new 350HO in a 20' Imperial cuddy cabin. The engine has been flawless every season. It does call for 92 octane. I have used mostly 89 and some small amounts of 87 and really don't notice a big difference. With fuel cost at these levels, what would running 87 do to the engine? At this point I certainly don't want to compromise anything. I was just curious to hear from a good engine person out there.
Tom
madorno1 is offline
Old 05-07-2008 | 08:58 PM
Wobble's Avatar
SORE MEMBER
Boat motors run at maximum load coming on to plane and accelerating, the very small amount you save with 87 octane may well cost you a burnt or dropped valve or even a broken piston due to detonation.
I would stick with at least 89
Wobble is offline
Old 05-07-2008 | 09:12 PM
hunster's Avatar
Once I was filling up the scarab with premium and got a 4 hour dissertation on why I shouldn't use it. I'd go with what the mfgr says at the least.
hunster is offline
Old 05-07-2008 | 09:57 PM
Wobble's Avatar
SORE MEMBER
a 350HO isn't a boat motor, that I know of. Sounds like a GM crate motor
Wobble is offline
Old 05-08-2008 | 12:37 AM
articfriends's Avatar
You will destroy that motor if you continue to run it under a load with 87 octane,it was built to run on 92. I had one in a 1/2 ton truck a few years ago,if a gas station lied about their octane it would spark knock and rattle hard. It would rattle on 89 also,your problem is you'll never hear the detonation in a boat,it will just crack one of its hyperutectic pistons and come apart. I broke a piston at 22,000 miles on mine,switched them to forged,luckily the skirt that broke just made a constant ratlle and moved up and down with the piston instead of ending up wrapped around the crankshaft,Smitty
articfriends is offline
Nic
Magnum Marine
9
10-21-2008 05:12 AM
Pantera24
09-10-2006 12:50 PM
Jeffrey
Cigarette
42
09-08-2005 05:47 AM
S-24
15
01-19-2004 07:57 PM
HyperBaja
3
12-09-2002 09:03 AM
