Oil Temp Help Please
Old 05-21-2008 | 09:04 PM
nitrousnolan's Avatar
Default Oil Temp Help Please
Ok guys where does your oil temp usually run, and what temp at what Rpm's, reason I ask is I was out with a friend today and when we ran the boat(35 Lighting) with 465hp 502ci's the water temp ran 140-160 and the oil temp ran up to around 300 on a 3min or so WOT run, when we slowed down the temps came down slowly and eventually didn't run much of any temp when running at 3000 rpm's, The motors came out of a boat that had lavorsi guages and this boat has Stewart Warner guages, all guage sending units are from the boat with Lavorsi guages, all guages seem to work fine except for the oil temp or the boat is running HIGH oil temp. What do you guys think?? Is this ok??? is the guage not working ecause of the sending unit not matching or another issue??? These motors ran great in the other boat and never had any issues.
nitrousnolan is offline
Old 05-21-2008 | 10:45 PM
both engines run about the same temp? if so I would guess the gauges are off... get a digital inf. gun & zap the oil filters
customryder is offline
Old 05-22-2008 | 02:29 AM
It needs sending units compatible with the SW guages.
Griff is offline
Old 05-22-2008 | 10:22 AM
Yup I think your right, Chris at sterndrive told me the same thing, Thanks for the knowledge.
Velocity Vector
0
04-03-2008 01:45 PM
GoCiggie31
7
08-19-2007 06:07 PM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
kook
05-15-2002 06:05 PM
