Do Blowers leak??
Old 05-24-2008 | 03:26 PM
Default Do Blowers leak??
When making boost I get fumes in the cockpit. Are b&M blowers prown to have a spot that leaks??
Any help would be grand...Chad
mcprodesign is offline
Old 05-24-2008 | 09:14 PM
Tinkerer's Avatar
could just be exhaust leaks that show up only under boost due to higher exhaust pressures.
Tinkerer is offline
Old 05-24-2008 | 09:59 PM
You mean "gas" fumes?
If you do, stop till you find it...under boost only? Check your intake gaskets at the heads, Blower to base gasket and anything else that seals off on top.
Your fuel line connections......
Back4More is offline
Old 05-25-2008 | 07:41 AM
I have a B&M 250. There are two version of gaskets intake to blower housing. One is a cut flat gasket and the other is the O-ring style. Use both to avoid leaks.
BadDog is offline
Old 05-25-2008 | 10:55 PM
You my friends are a life saver. (literally) ..I see the leak at the base of the blower. I'm going for the Oring and paper both ..Thanks.Again!
Old 05-26-2008 | 11:31 AM
You may want to check the blow off valve too (if you have any)
mine has the valve mounted on the intake manifold ,and its spring loaded ,and can open if boost press is too high ,or the springs are not tight enough,some call this a burst panel ,that can openup when a backfire is pushing the valve open to protect the rotors in the blower
I used loctite 574 on my O ring ,and on the surfaces ,this works great.
Oh and watch out not to overtorque the nuts /studs that holds the blower on the manifold ,don,t know the exact torque values ,but its not that much,because of the blowercasing will deflect under too much torque,and the rotors will hit the casing
stirling is offline
Old 05-26-2008 | 05:53 PM
mcollinstn's Avatar
anything that has a pressure differential from one side to the other is a potential leak.
All over your boat, there can be things spurting out of pressure lines or out of gasketed surfaces, and there can be air being sucked into things that are under vacuum.
It's a constant battle...
mc
mcollinstn is offline
Old 05-27-2008 | 08:59 AM
mc
Hey BIG DADDY spray starting fluid along the base of the blower and if the motor revs you've found the leak , and Locktite is not recommended for gaskets DRY will work perfect ..good luck
redcorvetteman3
2
05-15-2008 11:46 AM
merlin
Wanted
9
02-03-2008 10:30 AM
chewy1955
Cigarette
1
10-18-2005 01:23 PM
JJONES
6
09-12-2005 05:25 PM
tomjarrell
02-03-2003 09:11 PM
