Engine Alarm constant over 4500 rpm
Did the shore dreams for kids today on my second run I started getting a constant alarm over 4500 rpm.And two shorts beeps every few minutes under 4500Rpm.It is not getting hot 175-180 and have plenty of oil pressure.The alarm is on the starboard engine.That engine also requires about an inch of throttle movement to stay running it stalls if throttles are all the way down.Will scan it tomorrow to see if there are any codes.All my fluid levels are fine and there appears to be plenty of water coming out of the exhaust.
Any ideas?
Any ideas?
Tim, My brothers 271 fast tech did the same exact thing last year did it a bunch of times and we could never find out why and it just stopped all by itself. If you figure it out let me know we tried everything even ran computer diaignostics and came up with zip. good luck
Charter Member #415
Scan tool will tell you the code. There are so many sensors that set off the alarm that you have to use it unless it is low drive oil(90% of beeper problems)If drive oil is ok,scan tool will tell you.We had a shift position switch go bad last week,told the ecm that drive was jumping out of gear. It wasn't,but ecm thought it was. But if engine is not going into guardian mode,then like the previous post,I suspect drive oil.Low drive oil triggers the beeper,but not guardian mode.
Charter Member #415
Just got a call from a friend and tech guy,he said IAC(Idle air control)He said same symptoms on 3 boats recently,IAC solved it.I trust what he tells me.The IAC is not very expensive and easy to change out.
I had same symptoms on my 292 with 6.2's. It was a bad IAC. Tech told me it is a very common problem with those engines. Heat from the engine cooks them. Very simple to change. Just take off top engine shroud and its right there. Will need the gasket too, if that is your problem. Later that same weekend, lost a water pump impeller. That was enough problems for one weekend. Changed both water pump impellers just for good measures.
