Whats the Difference ??  LED vs Neon in the Bilge >
Old 10-14-2008 | 06:10 PM
  #31
Strip Poker 388's Avatar
Rob
Originally Posted by Jigsaw89
Looks Great... mirrors would put it over the top!!
Thanks, I just need to figure out how to do the mirrors on the hatch.I dont have any good picks of a Hustler with them, its curved in the back.Thought about using 1/8-1/4 star board as a backing, dont know if it could be glued ,or if it will stick????
Strip Poker 388 is offline
Old 10-14-2008 | 08:02 PM
  #32
LubeJobs42's Avatar
[QUOTE=Strip Poker 388;2684007]I am looking for some neon/led lights for my engine compartment. I did a search here and saw a few threads on it ,
but there's no definitive answer. Ive seen the Sunsation F4's they look like they have a bright kit in them.
One thread suggested Street Glow name brand.
Trying to decide on length and the led or neon in blue.Thanks for any suggestions
Rob, I just bought a bunch of these for my truck and boat. They are LED's and Stobes in one. No Power supply box needed. These are the coolest lights they have ever come out with!
http://www.oviedosafetylights.com/St...acement_System
Only 7/8" in height, this small hemispheric LED lighthead is perfect for most applications where size and intensity are critically important. Self-contained unit using an in-line combination lamp driver/flasher. This new self-contained LED Hideaway requires only a one inch hole in any composite style head light, cornering light or tail light assembly to deliver true wide angle warning to the front, side and rear of your vehicle… without interference to your vehicle computer and warning equipment! Less than 1" tall, it may also be surface mounted to outside surfaces anywhere on the vehicle! FEATURES * Ultra small, self contained, semi-hemispheric LED light, for surface mount or internal mount within composite head lamps, cornering lamps and tail light assemblies.
* 25 Scan-Lock™ flash patterns, includes synchronize feature for alternating and synchronous flashing of multiple lamps.
Attached Thumbnails Whats the Difference ??  LED vs Neon in the Bilge-led-strobe.jpg
LubeJobs42 is offline
Old 10-14-2008 | 11:22 PM
  #33
Rob
Originally Posted by C_Spray
As soon as you get the mirrors on, you'll get plenty of relected light on top of the engines. I had planned to put lights on the bottom of my hatch, but once I saw the results of the strip lights being reflected, I'm not so sure that I need them.
Looks good. How many colors can the kit generate?
.red is dark,blue.a blue/green,green,yellow,white,turquoise,coral, it does all that other crazy blinking stuff to.The kit was around 206.The controler box is pretty chep looking , but there all from overseas
Also the plastic tubes, it feels pretty tuff, I could bend it a little to get it under the transom inner lip.
Main thing for the mirrors is the day time,we very seldom are out at night,only one bar/restaurant on the lake, its 500 yards sfrom my slip
Old 10-14-2008 | 11:27 PM
  #34
Rob
Originally Posted by 29Firefox
Looks damn good! Check these guys out for your hatch mirror.
poke around on the site and look for the product called Fabback Marine Grade Mirror
http://www.plaskolite.com/
does the fabback have a backing so the silver/mirror want chafe/rub off? bigest peice said 24x48
Do you all think the mirror could be glued to star board and stay?
Old 10-15-2008 | 03:17 PM
  #35
Jigsaw89's Avatar
3M 5200 should do the trick.
Jigsaw89 is offline
gerard
09-03-2008 04:40 PM
Westcoast
02-03-2007 03:35 AM
stonecaster
09-22-2006 08:35 PM
LubeJobs42
03-17-2006 01:58 PM
SinkorSwim
Sutphen
5
11-19-2002 01:14 PM
