Whipple Hemis
Old 03-06-2002 | 04:54 PM
thunderdan's Avatar
WOW, nice looking motors-what kind oh HP are you looking for?
thunderdan is offline
Old 03-06-2002 | 05:45 PM
Charter Member#1300
Thumbs up
looking good Dustin! Now lets get them in the boat!!!
Stray Cat is offline
Old 03-06-2002 | 06:29 PM
Niuhi's Avatar
Charter Member #971
Let's see some more info on the motors. For those of us that are fanatic Chrylser fans those are something to worship.
Les
Niuhi is offline
Old 03-06-2002 | 07:05 PM
Fever500
So THAT'S where all the Blue Paint went!!
Old 03-06-2002 | 08:04 PM
Evil Twin
Dustin,
I started out hot rodding Big Block Mopars! Those babys look sweet!!!
Old 03-06-2002 | 08:11 PM
Nice, better keep them under lock and key. There was a picture on a cover of a mag. last year of ypur motor--beautiful. How about a poster size picture of that motor with the dyno sheet. You shop owners get all the cool stuff. What drives are you going to try and destroy with them babies? Way too cool!!
cobra marty is offline
Old 03-06-2002 | 09:50 PM
Whipple Charged's Avatar
These are the 528 crate engines that us and Mopar worked together on, crate motor with Ross pistons, 7.5:1 compression, Crane Hydr. roller camshaft, inconel exhaust valves. They make a bit over 1200hp at 6200rpm, 14lbs. of boost. 1200lbs. of torque .
Running some of Imco's latest drives. Got them to idle at 775rpm so shifting will be fine. Going on a 28' Eliminator Daytona. The good news is that I can change the spark plugs easy ! I've never done anything simple, you would think I would learn someday.
Thanks,
Dustin
Whipple Charged is offline
Old 03-07-2002 | 08:54 AM
Dustin wrote:
"I've never done anything simple"
It looks like you've got water cooled adapters between the heads and exhaust manifold. Were those off the shelf or did you make them.
Gary
Gary Anderson is offline
Old 03-07-2002 | 09:14 AM
It has always been Chevy blocks bolted up to Merc (and derivatives) drives. Other engines have always been a problem. How do you adapt those engines- are the adapters (bell-housing, flywheel, couplper, etc) a custom-built piece?
jafo is offline
Old 03-07-2002 | 12:44 PM
Gary,
The exhaust adapters were custom built.
The bell housing has a CNC billet piece that adapts it to the Chev pattern. The belt system, brackets, EFI, etc. is all custom made by us.
Thanks,
Dustin
