low and high gear?
Old 09-26-2008, 10:19 AM
Default low and high gear?
Looking at a boat with a #6 on it and the description says it has a low and high gear?
I didnt see a clutch pedal
So Im assuming this is something that you chose the gear before you select the rotation of the drive? Im not familiar with these.. Do they "shift" at a certain RPM?
Whats the advantage of this? It seems like youd come off plane if you lowered your RPM by shifting to a higher gear at speed..
waterboy222 is offline
Old 09-26-2008, 02:07 PM
ZBODaytona's Avatar
two speed tranny...i know they run some....
ZBODaytona is offline
Old 09-26-2008, 02:14 PM
Airpacker's Avatar
two main reasons for using 2 spd boxes. One, BIG PROPS and docking. Low gear allows engine to idle while slowing down the prop. Two, low gear allows a motor pulling a big prop to come into its torque cure much easier for planing purposes.
Airpacker is offline
Old 09-29-2008, 08:00 PM
so will there be a seperate gear shift for these speeds?
Old 09-29-2008, 08:11 PM
SeaRay Sundancer
tblrklakemo's Avatar
It could be that the boat comes with two gear sets for the #6. A high and low gear set. You will, of course, have to take apart the drive to change them.
tblrklakemo is offline
Old 09-29-2008, 08:33 PM
Brad Zastrow's Avatar
It is possible the boat has a two speed transmission not the drive. It would be an electronic shifting tranny possibly made by B&M. Not the most reliable transmissions. Best thing is ask the seller for details.
Brad Zastrow is offline
Old 09-29-2008, 09:53 PM
Skater Brother
FREEDOM US1's Avatar
We have been developing a two speed tranny. The first set has been in Freedom US1 46 Skater. Great for parking!!! Things are looking good. We ran them at the Chicago poker run and LOTO. I can't break them!!! We will start taking orders for them in Sarasota, Speed Shift Transmission is the name of the company. Come to Sarasota this weekend a check them out!! 316-648-2414 Thanks, Jim Lee
FREEDOM US1 is offline
Old 09-30-2008, 06:09 AM
Quinlan's Avatar
Jim thanks again for the ride in FREEDOM before Uglys run. I just wanted to say it IS a SKATER NATION!!!!!!!!!!!!!
Thanks, Quinlan
Quinlan is offline
davis777
1
07-13-2006 07:19 PM
two-air
1
05-09-2005 08:21 PM
The Menace
14
09-08-2004 11:34 PM
Vyper340
Powerquest
1
06-29-2002 04:38 PM
Quick Reply: low and high gear?
