1995 mercury 2.5 offshore
I need so help. All of a suden my ignition and my trim quit working. I checked the one fuse that my manual shows and there is no loose wires. Is there more fuses than just the one. I am new to the outboard scene. Has anyone ever had a problem simalar to this. Thanks
First thing is get yourself a meter and make sure your getting 12 volts, I had the same problem on my trim pump, good luck:cool:
If you got a 2.5 your trim pump is in your boat check voltage at the trim pump also. |
| All times are GMT -5. The time now is 10:28 AM. |
