Drain the gas??
Old 11-29-2008 | 01:31 AM
Stabil nor sea Foam will prevent octane loss over time. Fuel loses octane at up to .5 points a month. In 10 months it could lose up to 5 octane points. Add the high octane to get it back up to where it should be. At this point, I would just wait till Spring to add it.
Griff is offline
Old 11-29-2008 | 08:00 AM
90Velocity's Avatar
Originally Posted by 30ctsutphen
Ethanol will attract moisture that is true but I am told it will also help bring that water trough the combustion chamber and burn it if it does get contaminated.
at least thats what I have been told by New england race fuels.
I'd like to hear more discussion on the ethanol and water attraction. Water is heavier and ends up at the bottom of the tank.
90Velocity is offline
Old 11-29-2008 | 09:21 AM
TEAMBAJA's Avatar
Originally Posted by daredevil
What is sea foam ??????????????
I have personally never used the stuff, but I have heard it works well. There's some good info here on their products.
http://www.seafoamsales.com/products.htm
TEAMBAJA is offline
Old 11-29-2008 | 10:32 AM
seafordguy's Avatar
Ethonol is Hydroscopic so it holds moisture.
Just top it off in the spring, throw in some sea-foam if you are real concerned and change your fuel filter before and after if you are REALLY concerned.
seafordguy is offline
Old 11-29-2008 | 12:34 PM
There are pages of discussion about this all over the board.
Griff is offline
Old 11-29-2008 | 03:54 PM
Thanks for all of the replies, guys. Fortunately, we're down here where we boat all year, so I don't have to worry about storing it for the spring. Guess I'll put some good new gas in it with some octane boost and let 'er rip.
wantingmore is offline
Old 11-29-2008 | 03:56 PM
Originally Posted by TEAMBAJA
If you havent used it since June when the fuel prices were still high, there is a good chance its already been siphoned out!
Jason and I were just down there. I guess we should have looked you up when we hit the water.
Jason did call when he was here recently. I wasn't able to get down to the beach because of family commitments, but will definitely get there next time.
wrasse
03-12-2022 03:39 PM
JBoat
07-01-2008 05:42 PM
fountainguy214
Fountain
1
05-31-2007 10:39 PM
JasonSmith
07-18-2005 07:52 PM
